02-13-2008, 11:34 PM | #1 |
Air Ride - Compressor and Tank Location Help
Could I get some pics/ideas on where some of you may be mounting your air ride components: solenoid block, tank, compressor.
Thanks in advance! |
02-14-2008, 12:06 AM | #2 |
Re: Air Ride - Compressor and Tank Location Help
No pics but all my stuff is mounted under the bed behind the rear axle.. 2 3 gallon tanks, valves and compressor all up under there.. Very clean looking..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
02-14-2008, 03:14 AM | #3 |
Questionable
You'd be better of posting to ask about it at the Suspension forum, which is dedicated to topics like this.
most people put them on the framerails or crossmember just behind the cab, or on the rear framerail or crossmember. Some examples: http://67-72chevytrucks.com/vboard/s...9&postcount=11 http://67-72chevytrucks.com/vboard/s...&postcount=420 I can't find the good ones I think I saw in one of SCOTI's threads.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
02-14-2008, 04:39 AM | #4 |
Sophomore Member
i mounted solenoids on the outside of passenger frame rail. i mounted my tank and compressor inside passenger front of bed. everything was in same area.
1972 Chevrolet Highlander SWB 1972 Custom Deluxe 3/4 2WD 60k miles these trucks don't need vacuum gauges cause they don't suck! two wrongs don't make a right, but three rights do make a left all i want is a little more than i'll ever get it's better to be judged by 12 than to be carried by 6 |
02-14-2008, 05:35 AM | #5 |
Questionable
i apologize, it was NOT actually SCOTI's thread I saw it in, but he posted in it quite a few times. it was actually n2billet's work (and N2TRUX also?) here:
http://67-72chevytrucks.com/vboard/s...54&postcount=5 http://67-72chevytrucks.com/vboard/s...58&postcount=6 That should give you some ideas. Notice the compressors up behind the cab on the framerail? I've also seen people mount valves on a fabbed (aftermarket) crossmember across the frame back there. But, in general, all of the links I've provided and other pics and info guys have provided here show the "common" ways a lot of the other guys around here do their stuff.
02-15-2008, 12:00 AM | #6 |
Good information, thanks everyone.
