02-14-2008, 11:17 AM | #1 |
Finding interior paint
What I'm looking for is the dark olive paint(semi-gloss/satin) that they spray between the dash pad and the windshield. LMC sells a vinyl paint but I'm not sure that will stick to metal...any thought or recommendations.
1972 c-20, 350/350, dana 60 w/456 gears(no Posi) |
02-14-2008, 11:28 AM | #2 |
Re: Finding interior paint
why not just regular automotive paint
72 LWB |
02-14-2008, 11:42 AM | #3 |
That's what I thought until I visited a paint store and they said that they could not make it in a satin or flat....that info could be wrong. If any one has been able to get it, I would like to know what to tell them. Any help would be appreciated.
02-14-2008, 11:39 AM | #4 |
Sierra Grande Club
^^ & have them put it in a spray can.
st
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
02-14-2008, 11:40 AM | #5 |
'71 chevy s.bed/s.side
I painted the interior and exterior with bc/cc. On the area of the dash between the pad & windshield, I sprayed the base coat and bought a pint of matte finish clear coat and sprayed it. I was very satisfied with the results. The color matches and the finish is matte, almost a flat finish. You can actually mix the gloss clear and the matte clear and come up with your own finish, anything from flat to eggshell to semi-gloss, etc. If you do not want to go that route and you're using single stage paint, you can buy a flattening agent to mix in the paint and it will give you the same effect. I believe Eastwood and other rattle can suppliers sell a matte finish clear in the spray can. Hope this helps.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
02-14-2008, 12:09 PM | #6 | |
I lke the single stage idea, I'll go to a differnt paint shop and see if they can add a flattening agent. I'm trying to make it as simple as possible.
