Old 02-15-2008, 03:39 AM   #1
pat
pat's Avatar
Check engine light, stumble, power loss
Ive got an 90 Jimmy with a 350 and I will be driving down the road just fine when all of a sudden it will kinda stumble. Immediately the power will go down and it wont be very responsive, and the check engine light immediately comes on. I havent checked the code yet, that may help.
Any ideas?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 02-15-2008, 05:07 AM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Check engine light, stumble, power loss
Check the codes and tell us what they are.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-15-2008, 10:22 AM   #3
pat
pat's Avatar
Code 42
Old 02-15-2008, 10:49 AM   #4
ChevyTech
Code 42 can be set by a bad distributor module, a bad ECM, or wiring problems between the ECM and distributor.
A code 42 will get set when the set timing connector is unplugged to set the timing. Make sure you clear the codes after setting the timing.
When the problem is present that sets the code 42, the truck will be running in a backup mode without electronic spark controlled timing.
It sounds like heat could be causing the distributor module to break down. Many stores like NAPA in my area will test the module for free if you bring it in.
Make sure when you install or reinstall the distributor module that you use heat sink compound/grease under it. The grease helps dissipate heat from the module.
Old 02-15-2008, 12:50 PM   #5
pat
pat's Avatar
Your knowledge never ceases to amaze me ChevyTech.
I guess Ill call around tomorrow to find a place to test the module first off.
Old 02-15-2008, 01:17 PM   #6
dadsbrew
dadsbrew's Avatar
My suburban just started doing the same thing last week, little different, it will stumble and run bad until shut off and restarted or stumbles and shuts off. same code 42. I guess I know what to check first now, thanks
1970 K-10 400CID, to much cam--not enough compression Stan's Headers and a 4" lift / 1990 R1500 Suburban 4X4, 350CID with vortec heads, edlebrock intake, TBI, 10:1 compression and Stan's Headers
"The probability of someone watching you is directly proportional to the stupidity of your actions"
dadsbrew is offline   Reply With Quote
Old 02-15-2008, 07:45 PM   #7
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
I have had this problem for A LONG time... and I did replace the distributor module. I also installed the grease... but I'm wondering if I installed enough underneath it?
Keep us posted on what you find..
Thanks,
Anthony
CLASSIC87' is offline   Reply With Quote
