Old 02-15-2008, 03:40 AM   #1
pat
pat's Avatar
Turn signal works some of the time
Ive got problems with my right turn signal. It works about 1/4 of the time, seems like it follows no pattern as to when it decides to work. It has a new bulb. Could it be the turn signal switch?
The left side always works perfectly.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 02-15-2008, 04:00 AM   #2
slug
slug's Avatar
Re: Turn signal works some of the time
could be a bad bulb socket, next time it goes on the fritz, leave the turn siginal on and get out and check to see if one or both of them is "on". if just one is out then i would check the socket of the one that isn't working.
slug is offline   Reply With Quote
Old 02-15-2008, 06:05 AM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Also check that both bulbs front & back are of the same number, I.E. 1157 or 2057.
Intermixing these numbers will cause the lamps on the effected side to act as you've described. They do look alike but the 2057 is a bit heavier duty bulb and will last a bit longer + it's just a bit brighter bulb as well.
As soon as I can find my bulb specs catalog I'll post the exact differences.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 02-15-2008, 07:02 AM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
if all else fails check the flasher unit
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is online now   Reply With Quote
Old 02-15-2008, 10:21 AM   #5
pat
pat's Avatar
The front light is on, the back is off. How would I know if the socket is bad?
The rear bulb is a 2057 and the front bulb is a 3057.
How would I go about doing that?
Old 02-15-2008, 01:27 PM   #6
BLE 'BURBAN
Sounds like you have the same bulb configuration I have/had in my '90 burban I take it you have single headlights and not duals on each side of your blazer correct? If this is the case then you should have 2 turn-signal lamps per side up front and just a single in the rear. #3057NA's with the flat "wedge" type bulb in front and the 2057 in back is correct. Your front SIDE MARKER LIGHTS also flash alternatly with the front turn-signals.
Here's what you do;
Turn on your lights and do a walk-around. Making note of any bulbs that are not lit up to include your rear side markers and headlights. May as well check them all at the same time.
Now reach in and turn on your HAZARD LIGHTS and again do a walk-around again making note of which bulbs aren't flashing but should be. Hit your HIGH BEAMS and check them too just for grins. Now set the parking brake or chock the wheels and put it in reverse to check your backup lights. Like I said you may as well check 'em all while your at it.
If everything looks good then time to check the flashers. Your vehicle has 2 of them, one for turn-signal use and the other for HAZARD LIGHT use.They are identical in every way except location.one is in the lower right corner of your fuse block the other one should be mounted just above and to the right of your go fast pedal. swap them and check just your turn-signals again.
Problem gone? Replace the flasher.
Problem persists? start checking your ground leads and sockets on the problem side.
Old 02-15-2008, 02:05 PM   #7
tyjoja
I've had problems with other cars getting dust and moisture in the hazard switch wich is part of the turn signal assembly. I got some silicone spray and worked it in around the hazard switch while working it back and forth and It worked for me. good luck bob
tyjoja is offline   Reply With Quote
Old 04-17-2008, 08:45 PM   #8
pat
pat's Avatar
I found out the problem a while back.
It was just a flasher unit.
