02-16-2008, 09:51 AM | #1 |
Advanced Adapters 205 ??????????????????
has any one used AA's 05-0405 adapter for the 4l60e to 205 trans case? They told me it would need to be mofited a little?? I dont see at all u have to grind the @#$% out of it! Anyone had this problem???
02-16-2008, 10:44 AM | #2 |
Re: Advanced Adapters 205 ??????????????????
Picts? I'd call thier tech line before you grind it into an unusable peice?
02-16-2008, 08:46 PM | #3 |
done that the say it has to me modifed??? Buy there parts and throw away the stock ones and it should work!!
02-17-2008, 01:48 AM | #4 |
We ordered the 0405 and the 6900 to adapt the 205 to our new 4L65E. Have not gotten it together yet. Is there anything I should know about this part before I install it?
02-17-2008, 02:00 AM | #5 |
if u use the stock adapter that can with the stock 205 u will have to take about 5/8s off the stock adapter. that is what i had to do on myn i would post a pic but cant figure it out. AA told me if i order there 205 adapter for 279 dollors i wouldnt have to modify it. I couldnt see throwing out the stock part?? I wish they would make it work for the adapter they send u BUT It will work with some grinding
02-17-2008, 09:10 PM | #6 |
You need to adapt the adaptor?What application was it designed to actually work on?
02-18-2008, 08:40 AM | #7 |
they say to adapt a 700 or 4l60 to your 205 trans case it works but with some work
02-19-2008, 01:17 AM | #8 |
I have not had to modify one yet. The instructions say they may need notched, but all the ones I received were already notched. You should be able to use a stock TH350 adapter, but depending on what transmission you use, may require either changing output shafts or like some people have done, build an extension adapter.
Mike Redpath |
02-22-2008, 09:00 AM | #9 |
what i am using is a 4l60e trans to a 205 tcase the part that they send u dont need to be cut on but to put it to the tcase u need to modify your stock adpt and sleeve DONE IT or DOING IT
