02-18-2008, 08:13 AM | #1 |
It followed me home?
np 208 input shaft ?
I am trying to swap tcases in my 85 k20 and found a 208 to swap in but it was behind a th400. It looks like the input shaft is smaller in the new case, my question is can I swap the input shaft from my tcase (sm465 tranny)? Hope that makes sense, thanks for any input ha ha
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
02-18-2008, 12:39 PM | #2 |
junk collector
Re: np 208 input shaft ?
Yes, the input shafts can be swapped. But, if you have never taken apart one of these t cases, Start with the junk one first. I cannot remember in detail how to split them the correct way without everything falling out. There are quite a few pieces that will scatter on the floor if you just open it up- i personally know this.
Try taking apart the junk case first, IIRC, just split it enough to get your fingers in there and hold everything in place and pull 1 half of the case off leaving everything in the other half. I cannot remember which half to leave everything in though, it has been a couple of years.
'87/89/76 K5 in progress '99 K2500 short crew '91 camaro rs '98 jeep tj '52 willys cj3a |
02-18-2008, 08:57 PM | #3 |
One shot, one kill.
Cochino:Remove the front drive shaft yoke then stand the transfer case up with the input side down. Remove the tailstock first then the case 1\2. Everything will stay in the forward case 1\2. Case halves do not split easily. Carefully inspect the position of everything as you go. Seeing as this is your first time, take pictures with a digital camera at each step to cover your ass. If you run into a problem you can e-mail me and I'll give you my number. Good luck, jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
02-18-2008, 11:01 PM | #4 | |
junk collector
