Old 02-21-2008, 02:51 AM   #1
bryanw1968
bryanw1968's Avatar
Broke upper right ball joint....
In half! The rim folded under the truck in the middle of an intersection. Whoops!
I replaced the bottom when I added disc brake drop spindles, springs, shocks and sway bars. I'm figuring that the original upper ball joints became the weakest link. Anyway are there any tricks to drilling out the original rivets or is it pretty straight forward?
Thanks,
Bryan
bryanw1968 is offline   Reply With Quote
Old 02-21-2008, 03:01 AM   #2
chevy one
Chevy One
Re: Broke upper right ball joint....
A 4 inch grinder will make fast of the factory rivets. Just grind off the tops and punch them out through the bottom.
Chevy One
67 1/2 Two-on-the-Floor
67 Nova 2Dr Sedan
03 Monte Carlo
I'M NOT OLD, JUST A CLASSIC!!!
chevy one is offline   Reply With Quote
Old 02-21-2008, 03:24 AM   #3
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Angle grinder works best, use a punch to knock them out when the heads are ground off. An air chisel will do it too, but it will be dirty.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 02-21-2008, 06:14 AM   #4
matthufham
dodge durango balljoints are on recall, we should of taken my dad's in before this. i drove it on 3 wheels for a block thinking i had a bad flat tire.
matthufham is offline   Reply With Quote
