Old 02-21-2008, 06:41 AM   #1
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Question Going Tubular
Is it worth it to go tubular? I am considering CPP stuff for my
newly aquired frame, but I am NOT going to go with Air Ride.
Does it make any sense other than it has that factor?
http://www.classicperform.com/Store/...k/6372TRSK.htm
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-21-2008, 08:47 AM   #2
1LoC10
Insert Title Here
1LoC10's Avatar
Re: Going Tubular
i would get just the CPP arms... then get the tubular cross member from Airride... and do the KP notch.... 2 inch lowering blocks... 6 inch lowering springs.. and a watts link
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 02-21-2008, 09:42 AM   #3
Shane
Shane's Avatar
Re: Going Tubular
I think all of it is awful purty, but almost a waste of cash ... it's a round version of the OEM stock square version. Performance wise you don't really really gain anything. Since you're planning on a static drop, i would go with the bolt in notch, drop springs, shock relocators, and adjustable trac bar ... no real need for a watt's link with a static drop.
good luck.
Shane is offline   Reply With Quote
Old 02-22-2008, 03:49 AM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Going Tubular
K, I have most of what Shane mentioned, it will need trailing arms based on
the pic's I got of the frame, so just arms and arm crossmember should do?
Old 02-22-2008, 04:10 AM   #5
MotorHead Lon
MotorHead Lon's Avatar
Re: Going Tubular
Check out the new Truck Builder mag. There is an artice on Blue Moon Motorsports tubular control arms. They are supposed to be for coil springs and offer an additional 1.5" drop. The web site is bluemooncars.com
I went with tubular because my truck is bagged and I hate to see the wheels way off camber when aired out. Like a certain 2002 Suburban in my town that has 22" wheels that nearly fold into the wheel wells when aired out.
88 Chevy C1500, step side, LS swap.
98 Crew Cab Dually, tow rig.
03 Dodge Neon. ECTA Ohio Mile record holder.
MotorHead Lon is offline   Reply With Quote
Old 02-22-2008, 06:31 AM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Going Tubular
They perform exactly like stock, just cost a lot more. Unless you really like the tubular look, I would just powdercoat a set of stockers and save the extra $500 for something more useful. JMHO.
GQ going 2-wheel?
EDIT: I would also go with ECE's crossmember if you're looking at doing that. It has more exhaust and driveshaft clearance as well as bolt-on brackets, should you decide to change your front trailing arm mounting angle.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-22-2008, 06:34 AM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Going Tubular
Originally Posted by gringoloco View Post
GQ going 2-wheel?
Yes,
I think the OE ones are junk, have not seen it
in person yet, just pictures from the owner
