02-23-2008, 10:34 AM | #1 |
Painting engine
Hey guys, I have an engine paint question. I see these custom trucks with the engine the color of the body. Is there some kind of high heat additive for paint? I would like to paint my engine the color of my truck, but don't know what to use to do this?
02-23-2008, 11:04 AM | #2 |
People know me
Re: Painting engine
one of my buddies did this to his engine,tranny,xcase and just used the paint straight up just like normal, the engine only gets about 200degrees, the paint will burn off around the exaust ports, not sure you can really do anything about that
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
02-23-2008, 11:16 AM | #3 |
Re: Painting engine
yep, car paint will work just fine
02-23-2008, 05:58 PM | #4 |
Step Brother
Re: Painting engine
02-23-2008, 05:45 PM | #5 |
Re: Painting engine
I use Dupli-Color paint on mine. Has never flaked or burned off. Comes in a lot of colors also. Just make sure that the block/heads are super clean and I used a light coat of primer before the paint.
1997 GMC Sierra Ext 1965 Mustang |
02-23-2008, 06:13 PM | #6 |
member
Re: Painting engine
If you use a chemical stripper before you paint, I used the Cooroless brush on primer to protect from residual stripper residue. It lays out real flat and the finish coat has held up well.
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide Last edited by olblue60@aol.com; 02-23-2008 at 06:13 PM. |
02-23-2008, 07:01 PM | #7 |
Re: Painting engine
make sure it's cleaned really good and prepped right and you'll have no problems... I painted my 28 roadster's engine with single stage and it looks as good today as it did 6 years ago when I painted it.
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50. |
