Old 10-24-2002, 02:14 AM   #1
BUXMAN66
go bucks!
battery keeps goin' south?
yeah,i got a wierd one for you electrical guru's out there! so any hoo,i buy me a nice tach. get it installed,run my lines to -1).ground on the body.2).light - to my headlight switch. 3).line to my hei dist. 4).power lead to switched power-key on. so how come everything works fine and dandy when on but something keeps killing my brand new interstate battery? when you push in on the lights it correctly turns off the light in the tach.,so there's no power drain there.obviously,when you turn off the ignition the rpm's go back down to "0".i have never had problems with the battery being dead after a couple of days until i hooked up the light to the tach. would there happen to be some kinda diode or something that is causing a slow ,trickle draw?checked the condition of my alternator by removing my positive battery cable, and the engine continued to run.would a bad voltage regulator do this?i have currently the old style external voltage reg. (was a good reason to go buy a 1 wire chrome 100 amp.,waiting on ups to bring it!) thanks for any help
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 10-24-2002, 07:27 AM   #2
chevyman 68 C/10
chevyman 68 C/10's Avatar
Turn everything off and see if there is a spark at the bat cable when you conect and disconect the cables. If so disconect the light to the tach and retry The spark will stop when you find the culprit.
I have never been a fan of interstate batteries, when I was buing used cars and salvage that was the only bat that you could count on to be a dud.
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air.
68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles
68 anniversary no engine long wheel base 400 auto FOR SALE
68 Chevy fleet side long wheel base complete parts truck.
chevyman 68 C/10 is offline   Reply With Quote
Old 10-24-2002, 07:56 AM   #3
gmcnorton
gmcnorton's Avatar
DRAIN
FIRST MAKE SURE EVERYTHING IS TURNED OFF... THEN DISCONNECT NEG BATTERY TERMINAL, HOOK TEST LIGHT TO CABLE AND TOUCH NEG BATTERY TERMINAL LIGHT SHOULD BE VERY DIM OR OUT COMPLETELY, PULL FUSES TILL LIGHT GOES OUT THEN YOU KNOW WHICH CIRCUT YOU SHOULD CHECK. IN YOUR CASE I'D START WITH TACH HOOK UP.. OR IF YOU HAVE METER YOU SHOULDN'T HAVE NO MORE THAN 50 MILLIAMPS OF DRAW ON GOOD SYSTEM.. HOPE TAHT HELPS YOU
70 GMC SHORT STEP , 71 BLAZER ,72 JIMMY,72 BLAZER, JUST NEED THAT SUBURBAN NOW......WANTING MORE
gmcnorton is offline   Reply With Quote
Old 10-24-2002, 12:05 PM   #4
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Disconnect the light you ran to the headlight wire and see if the problem goes away.
I think the dimmable lights put 12V on one side of the light all the time and the headlight switch pulls the other side of the lamp to ground through the big wirewound variable resistor in the headlight switch. It may be finding a path to ground somewhere other than where it should be.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 10-24-2002, 12:14 PM   #5
Project1970
14.1 @ 96MPH
Project1970's Avatar
Slightly OT, but the Interstate in my truck is the only battery I've ever seen go more than 1 year in one of our cars - 4 years and counting, now! (Of course, the others were a small handful of Delcos and a lot of Autozone batteries...)
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 05-01-2003, 11:03 PM   #6
Riveted1
Tasty Cakes!
Riveted1's Avatar
You guys rock. Gmcnorton, I used your technique (b/c I was having this problem, too). It ended up being a tach wire that the p/o had wired into an unswitched power connector in the fuse block. Sure did save me a lot of headaches!! Thanks again.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 05-02-2003, 12:05 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
When pulling fuses with the test light or multi-meter wired to the battery as described above, if you get all the fuses out and your still getting a drain, unplug the alt. They can crap out inside and drain...but still charge the vehicle when running.
Old 05-02-2003, 05:36 AM   #8
gmcnorton
gmcnorton's Avatar
information
glad i could help.. thats why this board is great. usually you can get anything fixed with help from someone on this board. it seem there is someone to help with any problem.
Old 05-02-2003, 12:20 PM   #9
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Buxman66,
Sound like you got something on constantly....do the check like these guys suggested.....you'll find it.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
