Old 02-25-2008, 01:24 AM   #1
soba_03
soba_03's Avatar
Power booster vacuum 235 I6?
Ok I have the booster mounted and spindles and rotors. Where can I tap off for the vaccum? Thinking about using the vacuum port form carb where the vacuum advance comes off. I need thoughts and Ideas please.
Thanks...
soba_03 is offline   Reply With Quote
Old 02-25-2008, 03:10 AM   #2
mbgmike
Re: Power booster vacuum 235 I6?
ON a 216 you can just tap off the vacuum conn for the wipers on the intake.
mbgmike is offline   Reply With Quote
Old 02-25-2008, 06:34 AM   #3
wild one
Registered.........
wild one's Avatar
Any place off of the intake manifold is fine, you want full vacuum to the booster
at all times. If there is a large nipple off of the base of your carb you can use/tap into that as well.
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 02-25-2008, 06:49 AM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
There should be a tap on the side of the intake which will give you the most vacuum for your brakes.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 02-25-2008, 10:24 AM   #5
soba_03
soba_03's Avatar
Fred,
That is where I wanted to go. But the plug has been in there since 61 when it was new and well even with some heat applied I'm afraid that it's going to strip out or crack. It's a tight SOB. So I was thininking about tapping off the vaccum port at the base of the carb where the advance for the distributor goes. I expect that it would not affect timing to tap off at that point as well.
Old 07-14-2008, 02:34 PM   #6
VDOG
Grand PooBaa Member
VDOG's Avatar
Ok I got the same problem, but I have an Edelbrock 1406 on top of a Weiland manifold, where do I hook up the booster, cause there is no port behind the carb.
VDOG is offline   Reply With Quote
Old 07-15-2008, 12:51 AM   #7
greg64
greg64's Avatar
Originally Posted by soba_03 View Post
Fred,
I cracked a 250 manifold trying to get one of those out. From that experience, I'd leave the stock plug alone, and drill and tap a new port for your brake booster. The manifold, obviously being cast iron, is an easy drill & tap.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 07-14-2008, 07:59 PM   #8
Fred T
Cantankerous Geezer
Fred T's Avatar
There is a port on the intake. Looking from the front of the engine, it is behind the carb on the left. You probably have a plug in the hole. You can go to the hardware store and buy plumbing fittings.
Fred
