Old 02-25-2008, 10:01 PM   #1
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
4X4 700r4 question
Ok guys, and gals. I did a search on swapping out the 350 for a 700 but didn't find much information on how to do it with a 4X4. I saw that the 700 is 1-3/4" longer. The question is do I move the engine forward or the transfer case backwards? Or a combination of the two. I would like to move the engine forward because the way it sits now the HEI rubs slightly on the firewall. Thanks any help will be appreciated the frame is going to the body shop tomorrow.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 02-25-2008, 10:24 PM   #2
extd56
extd56's Avatar
Re: 4X4 700r4 question
If you have room I would move it forward. You will also save money by not having to make a new front driveshaft and shorten the rear one.
extd56 is offline   Reply With Quote
Old 02-25-2008, 10:49 PM   #3
ckhd
ckhd's Avatar
I did the 350 to a 700r4 swap in my '72 'burb.
I posted some of my experiences back in 2005. I think it should answer many of your questions. Here's the link: My 700r4 experiences
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 02-25-2008, 10:50 PM   #4
1969k10stepside
Move the motor forward...
1969k10stepside is offline   Reply With Quote
Old 02-25-2008, 10:57 PM   #5
ckhd
ckhd's Avatar
I guess one thing that thread didn't really address is the motor mounts. I moved the crossmemeber that the mounts are on forward. I had to drill new holes to mount the crossmember in. Not a big deal, but it's 8 new holes in the frame. Measure at least twice, so you only have to drill once. I have 10 new holes in my frame!
Oh, and I did have to trim my fan shroud a touch for the power steering pump and for the harmonic balancer. Not much, just a couple little notches, and it was easy to do.
If you have any more questions or specific questions, ask. I might not see this thread again (I don't come by as much as I used to), so if you ask me something and I don't reply, PM me and I'll come back and find the thread.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 02-26-2008, 01:21 AM   #6
hilljob26
hilljob26's Avatar
After Reading That,do I Need A Different Adapter Or Will My Th350 To Np208 Transfer Case Adapter Work
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 02-26-2008, 02:44 AM   #7
6872xtc
6872xtc's Avatar
remember to watch oil pan to front diff clearance if the truck does not have a lift, it might be fine, but remember to check for suspension movement.
6872xtc is offline   Reply With Quote
Old 02-26-2008, 09:29 AM   #8
ckhd
ckhd's Avatar
Not sure about the np208, but whoever you get your tranny from should know. If they don't, I'd be a little nervous about getting one from them.
I didn't have any problems with oil pan clearance, and I'm stock height. I thought I'd have front driveshaft vs. tranny pan issues, but there actually was plenty of room.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 02-27-2008, 06:09 AM   #9
duallyjams
duallyjams's Avatar
I read on a different board that a th350/np208 and a 700r4/np208 adapters are different. Do you already have what you need or just researching.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-27-2008, 08:06 AM   #10
JayDubBlazer
go cyclones
no i am in the process of getting one, I will probaly give bowtie a call tomorrow
Wes
PROJECT OLE GREEN
2017 Silverado LT
