Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-26-2008, 11:02 AM   #1
LuckyHenriksen
LuckyHenriksen's Avatar
Twin Turbo Questions
I have a matching pair or turbos off big diesel truck engines, and was just curious as to what it would take to twin turbo my 68 LWB. And also curious as to how much boost the stock internals of a 6.0 LS- based truck engine could stand up too.
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 02-26-2008, 09:44 PM   #2
Super73
Super73's Avatar
Re: Twin Turbo Questions
Do these turbos have the waste gate built in to them? Most production turbos do.
Assuming you have the harness, computer ect...
Quick list of parts I know you'll need:
Blow Off Valve
Boost controller
Rod bolts
Injectors
Fuel pump (Walbro 255 should be ok)
HPtuners
As far as power it well it depends on your tune really. Obviously with an intercooler and/or Meth, you will be able to turn it up some more safely. Detonation is your enemy!! I would say you could put 500-550rwhp down fairly safely on the stock shortblock with rod bolts.
I would also keep the stuck truck manifolds and turn them backwards. They flow good and they will never crack. Guys have been in the 8's on them in F-bodies.
Super73 is offline   Reply With Quote
Old 02-26-2008, 10:07 PM   #3
Alex1
Alex1's Avatar
I would say around 8 psi to be safe. depends on the compression is it going to be intercolled etc... I recommend you go to this site for more info: http://www.theturboforums.com go to the forums!
You will have to figure out your exhaust system (custom headers usually required - although I just built most of the drivers side turbo header this weekend and it only took about an hour to tack up - BBC with single turbo) You have to be careful with some of the diesel turbos - some don't spool very fast.
Alex1 is offline   Reply With Quote
Old 02-27-2008, 12:28 AM   #4
LuckyHenriksen
Thanks guys that forum is just what i need
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 02-27-2008, 08:12 PM   #5
57sailplane
57sailplane's Avatar
This article does a good job of explaining how to set up a turbocharged engine. http://www.allfordmustangs.com/Detailed/20.shtml
good luck..
57sailplane is offline   Reply With Quote
Old 03-05-2008, 06:27 AM   #6
thewrai6th
Maximum Boost by Corky Bell is a very good read, I would recommend that.
I'm just wondering if there are more people on this board running fuel injection or carbs with thier turbo(s)??
I'm used to tuning 16x16 or larger injection and ignition maps. I'm looking to either boost the carburated 350 I have in there now, or put in an LT1 and boost that. I don't really like the idea of not having direct control over the entire tune, so I am leaning towards the EFI LT1. Any links to articles comparing EFI to Carburated 5.7L SBC's would be appreciated. Most of the banter on the net is 5.0 guys arguing back and forth. From what I gather, carburated has the most peak power potential but EFI gives a better and safer tune overall.
1969 Stepside restoration
thewrai6th is offline   Reply With Quote
Old 03-05-2008, 09:39 PM   #7
Alex1
Alex1's Avatar
Put it this way, both work very well! I picked up a C & S 950 cfm for about $1100 set up for my engine and for blow trough (still buying parts lol). People really love them! They've come a long way! CSU also sells good carbs.
Old 03-06-2008, 01:05 AM   #8
thewrai6th
Thanks! I found everything I need here: http://www.theturboforums.com, lots of good info.
Old 03-06-2008, 02:37 AM   #9
Alex1
Alex1's Avatar
Yup, I'm a member there too. Best site for turbos!
Old 03-09-2008, 03:38 AM   #10
scatesracing
Machinist
scatesracing's Avatar
My plan is for twins on mine.... "you dont plan to fail you fail to plan" i spend a lot of time on that site too http://www.theturboforums.com/smf/index.php
Last edited by scatesracing; 03-09-2008 at 03:45 AM. Reason: couldnt get the link to work
scatesracing is offline   Reply With Quote
