![]() Join Date: Jul 2007
Brake booster
Are there different sizes available? I have a 1980 and the brake booster is like 10-12" in diameter. I thought I had seen a newer pick up with a smaller booster on it. I would like to switch - I need more room for my turbo set up.
Any ideas? |
Re: Brake booster
Why not Hydroboost? That would seem like the perfect setup for a turbo'd truck.
- Greg |
Re: Brake booster
Re: Brake booster
All you need is the pump. No room??
My next suggestion would be manual brakes.
- Greg |
The One And Only !!!
Re: Brake booster
A higher powered engine with manual brakes ? Yikes !!!
With extra go you want extra woe.....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
Re: Brake booster
YEAH, that's why I'm looking into a smaller booster I need power brakes, this isn't a 2200lbs race car. I've found some universal boosters online (7") - I assume I could make it work!
#7 | |
Re: Brake booster
But your point about extra stopping power is a good one. I would suggest some larger diameter rotors on the front with some 4-piston calipers and an adjustable proportioning valve to set the front-to-rear bias.
- Greg |
