Old 02-29-2008, 06:46 AM   #1
KK2842
Post ??? Difference From 62 And 63 Parts
What Are The Main Reasons You Can Find Parts For 63 + Suspension Kits, Etc, But Not For 60-62 Chevy Trucks
KK2842 is offline   Reply With Quote
Old 02-29-2008, 07:23 AM   #2
kissingbug1978
Re: ??? Difference From 62 And 63 Parts
Because in 63 they changed from a torsion bar front suspension to the coil spring suspension.
kissingbug1978 is offline   Reply With Quote
Old 02-29-2008, 07:34 AM   #3
KK2842
Yes, But If I Repalce The Cross Member With All Componenets, This Will Avoid This Plrblem.
Whatabout The Rear End?
Kk
Old 02-29-2008, 08:29 AM   #4
leftcoast66
leftcoast66's Avatar
Kk
It should take away the issues, but I'm not positive if the frame rails are the same, if they are then yes the crossmember and then control arms and spindles I'd just upgrade while I was there to some dropped 5 lug ones or something like that, just do the money that direction instead of stock spindles. But ya, that should take away all of the issues.
leftcoast66 is offline   Reply With Quote
Old 02-29-2008, 09:35 AM   #5
PrerunnerRob
PrerunnerRob's Avatar
Do you have trailing arms or leaf springs in the rear?
PrerunnerRob is offline   Reply With Quote
Old 02-29-2008, 10:33 AM   #6
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Exclamation Re: ??? Difference From 62 And 63 Parts
THE BIBLE OF 1960-1964
The 1960 model year introduced a new body style of light pick-up truck that featured many firsts. Most important of these were a drop-center ladder frame, allowing the cab to sit lower, and independent front suspension, giving an almost car-like ride in a truck. Also new for 1960 was a new designation system for trucks made by GM. Gone was the 3100, 3200, and 3600 designations for short 1/2, long 1/2 and 3/4-ton models. Instead, a new scheme would assign a 10, 20, or 30 for 1/2, 3/4, and 1-ton models. Since 1957, trucks were available from the factory as 4-wheel drive, and the new class scheme would make this known, a C in front of the series number would indicate 2-wheel rear drive, a K would denote 4-wheel drive. Actual badging on trucks still carried the series name system from the previous generation. The 10, 20, and 30 series (C or K) were badged as "Apache 10", etc., 40, 50, and 60 series trucks were badged as "Viking 40", and the largest 70, 80, and 90 series models were marked "Spartan 70" etc. in 1960, C/K trucks were available in smooth "Fleetside" or fendered "Stepside" versions. GMC called these "Wideside" and "Fenderside." Half-ton models were the C10 and K10 short-bed trucks, and C15 and K15 long-bed trucks. The 3/4-ton C20 and K20, as well as the one-ton C30, were also available. GMC did not use the "C" nomenclature, though their 4x4 versions had the "K" designation. The 1962 model used torsion bar front suspension, with trailing arm suspension rear. Trim lines were base and "Custom." Engines included 135 hp (101 kW) 236 in³ (3.9 L) and 150 hp (112 kW) 261 in³ (4.3 L) straight-6s, and a 283 in³ (4.6 L) V8 with 185 hp (119 kW). GMC trucks were also offered with the 307 in³ (5.0 L) V8 engine, which ranged in power from 125 hp (93 kW) to 142 hp (106 kW).
A coil-spring front suspension came in 1963; along with a new base engine, a 140 hp (104 kW) 230 in³ (3.8 L) I6, and an optional 165 hp (123 kW) 292 in³ (4.8 L) I6. The cab was changed for 1964, with elimination of the "wraparound" windshield and a new front grille design, along with various interior changes. Air conditioning and a 220 hp (164 kW) 327 in³ (5.4 L) V8 came in 1965. A new base engine finished the model in 1966 with a 155 hp (116 kW) 250 in³ (4.1 L) I6.
C10/K10
C15/K15
C20/K20
C30
Production 1960–1966
Engine(s) 236 in³ (3.9 L) Chevrolet I6
261 in³ (4.3 L) Chevrolet I6
283 in³ (4.6 L) Small-block V8
307 in³ (5.0 L) Small-block V6
230 in³ (3.8 L) Chevrolet I6
292 in³ (4.8 L) Chevrolet I6
327 in³ (5.4 L) Small-block V8
250 in³ (4.1 L) Chevrolet I6
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 02-29-2008, 08:27 PM   #7
KK2842
currently have bars. would consider other options if need be
Old 02-29-2008, 08:39 PM   #8
slepysal
slepysal's Avatar
The rear end is also diffrent( If it has rear springs) on 63 up you can easily swap in a5 bolt 1972 rear end.The perches on 60-62 are spaced diffrently,and require you to reposition them .Also you must either remove and reinstall the pan hard rod,or fab one up.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 03-02-2008, 09:46 PM   #9
Chevyman680063
Chevyman680063's Avatar
http://www.classicparts.com/frame-truck-years.html
Chevyman680063 is offline   Reply With Quote
