02-29-2008, 10:45 AM | #1 |
fuel cell
anyone know were i can find the cheapest decent size fuel cell or any ideas on what i should do basically im getting a snap on tanneu cover and was gonna put the fuel cell in the bed next to the cab to get it out of the truck any other ideas on a tight budget
02-29-2008, 10:51 AM | #2 |
Questionable
Re: fuel cell
Get a 73-87 Blazer tank. That's about as cheap as you can get. Here is a thread with more info:
http://www.67-72chevytrucks.com/vboa...d.php?t=234732 Meanwhile, here's a cheap way to "delete" the hole from the stock tank filler for around $8: http://www.67-72chevytrucks.com/vboa...d.php?t=250995 Both of these threads and a couple hundred others are in the "FAQ/Truck Tech" forum. I highly recommend visiting that section before posting questions about doing stuff on the cheap!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 02-29-2008 at 10:53 AM. |
02-29-2008, 10:54 AM | #3 | |
Engine n00b
Re: fuel cell
Pretty sweet. You do the bed filler modification on yours? I NEED to do this soon. SIck of smelling gasoline. |
03-01-2008, 08:28 AM | #4 | |
Out of the carpool lane.
Re: fuel cell
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
03-01-2008, 08:51 AM | #5 |
Re: fuel cell
thanks for the help man i love this site
I can die happy now i own a c-10 TRICKNRACY cars baby TRICKNRACYCARS.ORG |
02-29-2008, 10:56 AM | #6 |
Questionable
Re: fuel cell
Bed filler modification? I think you mean tank filler
For the "tank filler" delete, that is my truck in the pictures I got the idea from another truck a member here locally showed me, and adapted it to make something that looks semi-stock. With some fab work I could've made it more stock (with neck and all) but I was lazy
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
02-29-2008, 11:32 AM | #7 | |
Engine n00b
Re: fuel cell
02-29-2008, 08:26 PM | #8 |
Questionable
Re: fuel cell
$6-$10 and you can relocate with no body work required.
The hardest part is keeping the rubber grommet intact when you remove your old tank, and also drilling the cap and the piece of metal pictured. You don't necessarily NEED to do it my way, it's just an example. You could use diff't materials and achieve the same results. I've seen this done a couple of diff't ways at this point.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 02-29-2008 at 08:27 PM. |
03-01-2008, 10:38 AM | #9 |
Re: fuel cell
Oh, I should mention that mine was from a Suburban and not Blazer. It came out of a '73. I'm not sure that makes a difference.
03-02-2008, 03:52 AM | #10 |
Gettin By on Gettin By
Re: fuel cell
This thread gave me the push i needed to go ahead and look for a cell. But i've got a question.
Local junk yard says the Blazer tank is the same as the suburban tank, can i count on that info?? *still a noob* They are asking 75 for the tank and sending unit, WAY more tempting then the 200+ for a kit. Doesn't the suburban have a wider frame?? LMC shows tow different tank part number, but that might just be the filler neck difference. |
03-02-2008, 10:22 AM | #11 | |
Re: fuel cell
03-02-2008, 12:14 PM | #12 |
Re: fuel cell
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
