Old 03-01-2008, 08:46 AM   #1
Couch
Daily Driver
Couch's Avatar
aftermarket wheel tubs and notch
never really done this but had some questions...
when it comes to size on these tubs. so i was wanting it to be able to tuck a 30 inch slick would the 32'' or 34'' tubs cover it.im not sure if i worded that right. is the measurement from the front of the tub to the rear.like wheel diameter?or is it how wide the tub is?
like on these
https://www.*****************/RoundTu...NotchCover.php
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 03-01-2008, 10:19 AM   #2
FnLow69
FnLow69's Avatar
Re: aftermarket wheel tubs and notch
"How do you know what size tub to buy? First, you measure the outside diameter of your tire, or it's total height in other words. You then add 4" to your tire measurement. This will give you 2" of clearance all the way around your tire. For example, if you measure a 20" wheel and tire you will get a measurement of about 27.5" to 28". The size tub you would need is a 32". The stock width of our tubs is 14". That gives you plenty of extra tub to trim it down for a perfect fit. If you need a wider tub for some reason just give us the measurements and we will be more than happy to build it for you.
Custom tubs are available. We can make you Hex shaped tubs, or tubs that drop down in the front for trucks like Blazers where the floorboard is not flat like a pick-up bed. You can fax detailed drawings with measurements to 812-782-3515 for a quote.
Price reflects a pair of tubs."
Copied for ***************** this should explain what you need....
FnLow69 is offline   Reply With Quote
Old 03-01-2008, 11:06 AM   #3
Couch
Daily Driver
Couch's Avatar
thanks a bunch man. im wanting to tuck either a 28 x 14.50 or a 30 x 14.50 slick. so i'll probably get a 34" tub. im running a swb stepside and i already dut the floor to clear and have been racing with it just cutout but i wanna clean it up now
