Old 03-01-2008, 10:57 AM   #1
Tomsriv
Tomsriv's Avatar
Radiator questions
So I took my radiator down to the shop to get a pinhole leak fixed. They told me that the core was leaking in several places. They could fix it for $45 but to do it right I will need a new core. For $320!, plus labor to put the tanks on. I checked my repair records and this radiator was last re-cored 15 years ago, and the fins are starting to disintegrate, so I would say its time for another. Darnit! I didn't plan on spending my government rebate check on a radiator! Most of the repo truck places want $400 plus for a radiator and Summit has a Griffin aluminum available for $457.
What should I go with? Also, this had a 4-row, but this is a 1/2 ton, short bed stepside with no AC, so I won't be putting that much load on it, even with a full bed. It has a healthy 350 V8, but I think a 4 row might be overkill. What do you think?
In addition, the Griffin radiator that is supposed to fit my truck has a 1.5" inlet and a 1.75 outlet. My current radiator has 1.75 for both. It measures about 22x25. Does that sound like the stock radiator?
Tomsriv is offline   Reply With Quote
Old 03-01-2008, 05:59 PM   #2
fuelpump
fuelpump's Avatar
Re: Radiator questions
Classic Parts is $325 and Jim Carter has some under $300. Check them out.
fuelpump is offline   Reply With Quote
Old 03-01-2008, 07:49 PM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
Summit also has some of their brand name radiators in aluminum for $209 with tranny cooler and $169 without cooler.
This is the one without the cooler. http://store.summitracing.com/partde...5&autoview=sku
And with cooler. http://store.summitracing.com/partde...5&autoview=sku There is not picture for the cooler type but I am guessing it is like the one without. Most guys are using these and by the tale of my tape measure these will be the biggest you can put in. They will not be a direct bolt in and you maybe have to fab up some brackets. I have a feeling they are not hard to get in.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 03-01-2008, 07:54 PM   #4
ratskin
You may want to check Advance, or some of the others-I checked with Advance, and the boss offered a new radiator for my 64 350(283 originally) w/air for $200 plus tax. I've got a pretty strong 350, and it will idle(and lope!) all day with the gauge just above center. Don't have the air back in yet, but don't anticipate any problems.
ratskin is offline   Reply With Quote
Old 03-01-2008, 08:57 PM   #5
slepysal
slepysal's Avatar
What year is it for ? On my 60 I took the radiator to a shop to have it boiled out for 50.00. No can do they said it needs to be recored for 300.00! I looked all over the place and could not find one so I had to have mine done.
On the 60 it bolts to the the rad support ( like they did in the 50's), there is no lowwer support.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 03-01-2008, 09:17 PM   #6
63 & 64 Bowties
and a few others
I used the same Summit that Chevy Fleetside did on my 64 w/350 and it works great. It has to go above the frame rails instead of between them, so I had to fab new mounts.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 03-01-2008, 10:43 PM   #7
Chevysdominate
Chevysdominate's Avatar
I cant vouch for the quality, but these shouldn't take any modifications and the price isn't to bad.
http://cgi.ebay.com/ebaymotors/ALL-A...spagenameZWDVW
Chevysdominate is offline   Reply With Quote
Old 03-01-2008, 11:37 PM   #8
63 & 64 Bowties
and a few others
Wow, I like that. Never seen it before.
Old 03-02-2008, 12:55 AM   #9
Chevy Fleetside
They are made in China... If you care about those things.
Old 03-02-2008, 01:24 PM   #10
64Magoo
I have that exact radiator and it fits great with no modifications except for thicker support padding (the things that cradle the radiator on the top). The fit and finish is top notch and it looks great peeking through my grill. I would recommend it to anyone looking for an inexpensive high quality radiator.
64Magoo is offline   Reply With Quote
Old 03-02-2008, 07:39 PM   #11
PA66C20
PA66C20's Avatar
This same guy sells the original copper radiators. I bought one a few months ago. I havent put it in, but I think I paid $320? and that included shipping from CA to PA. The finish and the rad are top notch. Anthony was also very easy to work with and very quick about everything. Hope this helps. Questions or pics about my copper radiator from him, please email shawn@craftygrannyscorner.com
Shawn
How can you tell if its a boy or a girl?
Guess we'll have to roll it over to find out!
PA66C20 is offline   Reply With Quote
Old 03-02-2008, 12:50 AM   #12
rickf
rickf's Avatar
No, does not sound OEM. The 1.5 top and 1.75 bottom is correct.
My supposed "OEM replacement" from brandX ($200) was like yours, though, with 1.75 top and bottom. The spigots on thermostat are 1.5,, so I got a flex hose with different ends to make the connection. So while 1.75 top and bottom is technically not correct, it is easy to make it work.
rickf is offline   Reply With Quote
