03-01-2008, 08:16 PM | #1 |
Engine n00b
ooo that smell
After running her a little hard, I am getting a sickening sweet smell. Antifreeze, I figure. I have no leaks.. however, the radiator usually hisses for a little bit while its cooling down. The smell's pretty pungent... sign of a failing head gasket? Anyone? Other things to look and check?
350 - stock - never rebuilt I checked oil, and added a quart, low but still a wet stick the tranny (powerglide) fluid is actually pink, so no burning there I don't think.... |
03-01-2008, 08:28 PM | #2 |
KEEP ON TRUCKIN'
Re: ooo that smell
Look at your oil, if it's brownish white looking you have a head gasket going on it. Check your floorboard on the passengers side for dampness, that would indicate a bad heater core. Can you trace where the hissing is coming from on your radiator, could be a small pin hole.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
03-01-2008, 08:30 PM | #3 | |
Engine n00b
Re: ooo that smell
03-01-2008, 08:32 PM | #4 |
Son of a gun
Re: ooo that smell
Radiator cap probably needs replaced. Take to a shop and have them pressure test you cooling system, that'll tell you if you have a leak. And it should cost very little to have done. If you were local, I would be happy to do it for you for free.
Bill BEATERS ARE NEATER |
03-01-2008, 08:33 PM | #5 |
KEEP ON TRUCKIN'
Re: ooo that smell
The hole you talking about for the cap? If so, get a new cap and start from there.
03-01-2008, 09:54 PM | #6 |
Re: ooo that smell
Yep, I would go with a new cap and see what happens. It should not hiss.
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
03-02-2008, 01:43 AM | #7 |
Engine n00b
Re: ooo that smell
Turns out I was way off. That sick sweet smell was acid eating my metal.
Battery was cooking cause the voltage regulator and alternator went south. $100 installed for a higher amperage one with an in unit regulator. The place was AWESOME btw. They rebuild starters and alternators, and have a decent amount of mail order only business from it. Anything custom, bigger batteries, bigger alts, etc. If anyone needs em, I would recommend em. Plus, 4 hour turn around from calling them to fixed on a Friday afternoon - you just CANNOT beat that http://www.google.com/search?hl=en&r...ator%2C+austin |
03-02-2008, 02:32 AM | #8 |
Re: ooo that smell
The only "cooking" batteries I every was near smelled like rotten eggs. The water boils off and the sulfuric acid is concentrated.
I has it happen to me just outside of St.Louis on the way to Texas....from Ohio. Nothing like a road-trip breakdown or the story that goes with it. |
03-02-2008, 04:17 AM | #9 |
Re: ooo that smell
BTW, that was a great Skynyrd song.
03-02-2008, 04:46 AM | #10 |
Engine n00b
Re: ooo that smell
03-02-2008, 06:28 AM | #11 |
Re: ooo that smell
...........Oak tree you're in my way
03-02-2008, 08:51 AM | #12 |
Proud Father
Re: ooo that smell
Have a blow for your nose....
1969 Chevy C/10 "My dad's, May he rest in peace" 1988 GMC Suburban 1/2 ton 2wd 1952 Ford F-600 1989 Toyota P/U "The Beater" |
03-02-2008, 09:12 AM | #13 |
Re: ooo that smell
now i got to go find my lynyrd cd! lol
03-02-2008, 07:18 PM | #14 |
Re: ooo that smell
Lynyrd rocks nothing is better then litsening to a good ole lynyrd cd while cranking out some work on the truck
03-03-2008, 05:39 AM | #15 |
Proud Father
Re: ooo that smell
After I posted last night I kept singing it to myself.
