03-02-2008, 12:32 PM | #1 |
Hey airbag guys...
A R T told me that their bags for the front of my 67, at ride height was the same as a 2 in drop spring. what I need is a bag that is the same as 2.5 in drop spring , so combined with my 2.5 drop spindle will give me 5 in drop up front. In back I got 6 in coils no c-notch. is there a bag for the back that will give a 7 in drop at ride height ? I dont want to use blocks cause of pinion angle issues. I know i will have to c-notch in back. Right now I would like to set and go, no compressor or tanks. does this sound do-able or not
03-02-2008, 08:19 PM | #2 |
It'd be alot cooler if you did
Re: Hey airbag guys...
uh.... let some air out of the bag?!?
03-03-2008, 01:00 AM | #3 |
Yea i thought of this too but will it effect ride quality at a lower psi ?How much psi to raise or lower .5 inch? I am knew to this so thanks for your patients
03-03-2008, 03:53 AM | #4 |
Chevy Truck Addict
Probably only a few pounds to lower it an extra 1/2" but I would suggest cutting the lower bag cups down to get the 1/2" you want... I cut mine down a little over an inch to get the front end lower.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
03-03-2008, 06:51 AM | #5 |
That sounds like a great way to fine tune my stance up front-thanks . How about in back where I need a 7 in drop? can I do that with bags only or do I need blocks too? Any suggestions for bags? RE7?, ART? Firestone?
03-03-2008, 07:02 AM | #6 |
7" drop w/bags only? Not that I've seen. Bolt the bags directly in place of coils & use lowering blocks & your there.
03-03-2008, 07:55 AM | #7 |
will I run into pinion angle problems with blocks? what about air bag suggestions? type/brand?
03-04-2008, 03:14 AM | #8 | |
03-05-2008, 11:26 PM | #9 |
You can also flip the trailing arm mounting brackets over. This will help with the pinion angle also.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-04-2008, 06:43 AM | #10 |
7" out back with no notch? Hold on to your teeth!
I have Slams RE7's in place of the rear springs and 3" blocks (only advisable with big rollers), and no pinion angle issues yet. I'm sure it's not optimum but there are wedges available to correct it if needed. With 1" blocks I wouldn't be worried. |
03-04-2008, 12:49 PM | #11 |
WOW, you guys are a great help thanks much. Now I just have to make time to work on it! Yes frizzle, its gonna get c-notched
03-05-2008, 04:00 AM | #12 |
A guy with a truck
Here's a pic of my truck at ride height with the bags at the 6" recommended installed height with 1.5" blocks. I'd guess it's around a 7-or-8" drop. The notches are mandatory at this amount of drop...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
03-05-2008, 04:06 AM | #13 |
Truck?? You have air on it too??????
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-05-2008 at 04:06 AM. |
03-05-2008, 04:56 AM | #14 |
A guy with a truck
As of this past weekend... Click me. And yes, I do have a sickness...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 03-05-2008 at 05:29 AM. |
03-05-2008, 05:30 AM | #15 |
A guy with a truck
Fixed.
