Power brakes- 3/4t & 1/2t
Is there a reason why a 3/4 t truck has the brakes lines flipped around- rear lines go to front of distribution block and front go to rear of block? Or I guess I should ask does it make a difference?
Reason I ask is I have a 3/4 ton truck and bought 1/2t lines. I can make them work as far as plumbing goes, but doing so hooks the front lines to the front of the distribution block and the rear to the back or the block. Also, any difference in manual & power master cylinders for drum/drum set up?
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
Re: Power brakes- 3/4t & 1/2t
anyone?
Thanks, but I know 1/2 & 3/4 tons plumb differently, I just wondered if there was a reason.
Also if there is a difference in master cylinders between manual and power on a drum/drum set up. So far I have not found an answer.
come on, some one has to know
its all about the +6 inches
master cylinder p/n for power and manual are the same.
thanks longhorn man
now how about if there is a reason for reversing the hook ups-- front brakes go to rear reservoir and back to front reservoir?
1972 Chevrolet SWB
My truck is a 1/2 ton with a 3/4 ton cab with the same mastercylinder and booster but I did mount the booster to the firewall without the extension brackets. here is a picture.
![]() I dont remember having any real issues mounting up my brakes but you can see for yourself the 3/4 ton set up worked fine.
My New thread with pics (not my build thread yet.) ![]() http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
1972 Chevrolet SWB
I can ake a better closer picture if needed,and yes the truck was driven for 3 years with this set up only put together for you smarties!! LOL
The mastercylinder is the type with 4 like sized reservoirs like Vettes came equipped with instead of the smaller rear brake/larger frt brake reservoirs.
My New thread with pics (not my build thread yet.) ![]() http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. Last edited by slammed1; 03-03-2008 at 09:23 AM. |
I would not hook it up backwards. can you return the lines?
I can't return the lines, they are already installed. I was thinking I will either hook them up reversed or take and cut off the flares flip the nuts around and re-flare the ends of the tubes. Just thought I would find out if there was a reason for them being reversed before I go to the trouble of cutting and flaring.
1972 Chevrolet SWB
Ace,I went back outside and looked at mine after I replied,and I will take a picture tomorrow in the light so you can see mine. I used my 1/2 ton lines and hooked them to the 3/4 ton prop valve. On mine the rear line is a larger diameter that feeds the rears and the smaller lines have a "T" at the left motor mount area and both the frt lines are the smaller diameter ones.
thanks, I'll have to go back out and look at mine too, I was thinking the nuts are different size but the lines are the same size, but I'll double check. Right now the cab is off and they are not hooked to anything so thats why I was thinking of just swapping the nuts around if there is a reason for the lines to be hooked up in a special way.
I thought that the reason for going to a 2 reservoir system is for safety. so if you loose 1 half of your system you could still safely stop. In a drum/drum set up there is no proportioning valve so I would think that the pressure would be the same to both front and back lines (basic hydraulics) and so it should not matter which line goes to which port but I have been known to be wrong before (at least once or twice ![]()
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited Last edited by Ace in the hole; 03-03-2008 at 05:43 PM. |
Ok, I confirmed that the lines are the same size, just the nuts are different.
#15 |
Just hang'n around
If you have front disc brakes, you need a proportioning valve for that system. The forward lines are also smaller for disk brakes than for drums. And the lines going to the front disks are smaller in diameter than the lines going to the rear. It has to do with the pressure leading into the brake cylinders at the wheels.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year. |
#16 |
I don't have discs, I have a power drum/drum set up.
#17 |
I have searched and searched and can't seem to find an answer to there being a reason for the brake lines being reversed at the distribution block on a 3/4 ton. I will more than likely change the ends around to keep them hooked up the way the factory had them, although I am kicking around trying it the 1/2 ton way just to see how it works.
#18 |
ttt
#19 |
![]() Join Date: May 2005
Hooked mine up with stock lines then bought the conversion lines from Inline Tube, could not tell a difference. I am putting rear disc on soon, wonder how that will work.
