Old 03-05-2008, 04:02 AM   #1
ldgn63
looking for a manual master cylinder for disc brakes...
hey all,
converting to disk brakes via drop spindles and over the counter 70's era replacement parts.
i want to run a manual master cyl but all the serching i do comes up with power only...
anybody know what manual cyl will work with discs?
maybe 71- 72?
its going in a '63.
thanks!
ldgn63 is offline   Reply With Quote
Old 03-05-2008, 04:04 AM   #2
ldgn63
Re: looking for a manual master cylinder for disc brakes...
wow, i thought i did an intro long ago....
sorry.
'63 SWB custom cab... owned since '84
it was my high school sweethart.
Old 03-05-2008, 04:11 AM   #3
jchav62
1962 C-10
jchav62's Avatar
71 or 72 non power front disc master cylinder should work. That's what my brother-in-law used in his 67, I'm sure you can make it work on you 63...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-05-2008, 12:33 PM   #4
wild one
Registered.........
wild one's Avatar
Yep, thats what I used on my '66. Funny thing is, according to the parts reference manual the master cylinder for power or manual brakes was the same for 1971/1972.
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 03-05-2008, 07:37 PM   #5
badriand
badriand's Avatar
Maybe i misread something but just go with the cylinder that matches the disk brakes of whatever year you decide to go with.
badriand is offline   Reply With Quote
Old 03-06-2008, 03:18 AM   #6
ldgn63
if i use all '77 (for example) wheel parts i cant use a '77 manual master cylinder because (i think) they were all power.... and power masters are different than maNual.
i could possibly use all 71-72 but drop spindles say 73-87....
Old 03-06-2008, 05:19 AM   #7
mbgmike
We sell new master cylinders that can be used for both power and manual. You just use the adaptor on the piston or not. Last time I checked they were 39.99 here at the store. They are copies of the original.
Mike
mbgmike is offline   Reply With Quote
Old 03-05-2008, 04:45 AM   #8
SeanPaintsFlames
SeanPaintsFlames's Avatar
but... why?
Could you get an aftermarket booster/master and resell the booster on ebay or something? Are master cylinders really power/manual specific? Hmm.
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 03-05-2008, 07:35 AM   #9
ldgn63
thanks.
on cars that i know of a manual master has a deeper recess and requires a longer pushrod... (or vica versa)
the bore size may be different... idunno
Old 03-07-2008, 10:17 AM   #10
PrerunnerRob
PrerunnerRob's Avatar
Originally Posted by SeanPaintsFlames View Post
but... why?
Yep, they are. Bore and stroke are diffent if you have power assistance. If you are driving a power boosted truck and turn the engine off, pump the brakes a few time to reduce the vaccum, this is the feeling you will have any time you will need to stop. Not good!
PrerunnerRob is offline   Reply With Quote
Old 03-07-2008, 10:20 AM   #11
PrerunnerRob
John(chiefrocka) recommended this to me, its a bolt in, I havent messed with the pedal rod yet, but should provide enough oomph to stop a truck. No personal experience yet, but for the price, you can give it a shot and see what happens!
http://www.partsamerica.com/ProductD...pe=230&PTSet=A
Old 03-06-2008, 06:59 AM   #12
greg64
greg64's Avatar
lgdn63, my 77 has factory manual brakes, so I can assure you that manual masters do exist. I think it's the rod from the pedal to the master/booster that changes, not the master itself (at least with this application).
Manual brakes and Armstrong steering leave a lot of room under the hood!
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 03-08-2008, 02:23 AM   #13
mbgmike
Like I said ,you change the piston rod length with the adaptor on this mc. not the rod from the pedal
We sell these AND install them
Old 03-07-2008, 09:09 AM   #14
ldgn63
thanks all...
the saga continues
