03-06-2008, 01:35 PM | #1 |
question about lowering blocks
I was wondering how lowering blocks work all the way around i no nothing about them i just no i have spring in the back does that make a difference and whats the lowest u can make them please a;; info is good i no nothing hahah?
I can die happy now i own a c-10 TRICKNRACY cars baby TRICKNRACYCARS.ORG Last edited by ohsocountry86; 03-06-2008 at 01:37 PM. |
03-06-2008, 05:49 PM | #2 |
Re: question about lowering blocks
As far as I know, you can only use lowering blocks in the rear.
On the front, you'll have to use drop springs or cut the coils off of the springs you have, or use drop spindles, or a combination of the three. For the rear you can use lowering blocks, drop springs, or carry a bunch of concrete blocks around with you, lol. These are the most simple means of lowering a vehicle, looking through this site you can see all kinds of elaborate inventions involving air baggs and custom frame modifications etc. |
03-06-2008, 06:16 PM | #3 |
Well lowering blocks mount between the axle tubes and either the leaf springs or trailing arms to raise the rear end higher. The actual suspension is not lowered. There is no way to lower the front end with blocks.
03-06-2008, 08:28 PM | #4 |
The Older Generation
Here is a good article about rear lowering blocks for the trucks.... http://www.classicperform.com/goingdown6772.htm I have 2" ones in the white truck. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-06-2008 at 08:29 PM. |
03-07-2008, 01:04 AM | #5 |
thanks guys djm offers 4 inch lowering blocks can those go on fine no other work needed no c notch or anything im getting 2 1/5 drop spindles and lowering springs(not sure what size in front yet) im trying to go daily driver low and have the back just slightly higher
I can die happy now i own a c-10 TRICKNRACY cars baby TRICKNRACYCARS.ORG |
03-07-2008, 01:05 AM | #6 |
2" is about the biggest block you can have without taking a risk of dragging the trailing arms if you get a rear flat. I have seen them as large as 4", but I would NEVER consider it. I have 2" blocks with 4" drop rear springs for 6" rear drop. This is an easy, reliable setup.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
