Anyone See Problems? Rear Mnt Battery
other than a pain to change and massive amounts of burnt rubber hanging off. does anyone see any problems with mounting the battery in this location?
has anyone tried it? any suggestions? comments? concerns? thanks |
The Older Generation
Re: Anyone See Problems? Rear Mnt Battery
From my experiences with my '39 Ford (battery in trunk) I wouldn't recommend it. If you do, use welding cable for your battery cables and use the solder on cable ends not the clamp on ones. I would also recommend running a ground cable to the motor from the battery instead of just using the frame as a main ground source. Also be sure and use ground straps from the motor to the frame and body. I melted two sets of clamp on battery cable ends before I figured all of this out..... ![]() LockDoc
Where did you get the battery box, or did you build it?
LockDoc - understand on the cable issues. i have ran rear mount batteries before and know the charging and grounding issues. i will also have charging lugs behind the rear flip down plate.
(Where did you get the battery box, or did you build it?) Smileys racing. they cater to the dirt track guys but you would be suprised what you can make work with some creativity... http://www.smileysracing.com/ more focused on fitment.... i might need some measurements... |
that look like my truck same tray @ same spot on frame.like lockdoc said use good cable @ solder ends on lots of good grounds i used frame for main ground but welded studs on frame for grounds . make sure you use battery kill switch at back of truck because you get a short you could burn up the truck.also need it if you drag race the truck.bought my tray at capital speed shop on line its a nice tray and its heavy duty
#6 | |
Did you weld it on or bolt it on? |
#7 | |
Sierra Grande Club
Other than that it looks good to me. I also recommended a maintenance free battery like Optma. I had a battery in the rear on my last car, it was great. Vaya con Dios s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Old member
Will it have enough room to be taken out with the bed on? If you aren't racing the truck why do you need it in the rear? Seems to be a lot of added work for no gain's. Cool factor isn't that great and you can have some pretty neat cover's made for the stock battery. Just my cent's worth.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
racing - more weight over the axle
there is just enough room to shimmy it in |
It's a catastrophic success.
![]() Join Date: Jan 2003
I put two in the back, used welder wire about the size of your thumb.Never had to use it as a DD but never ran into problems.
welded it on i think bolts may dig into battery.used a optima battery red top put battery switch under roll pan near plate
I did the same thing but on the passenger side to help balance my girlish weight.
I know what your thinking.......I have ESPN. ![]() Sometimes it's easier to do things the hard way. ![]() Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! ![]() ![]() |
