Questionable
I know, if you've seen one, you've seen a thousand rear diff covers. I'm assuming on my '68, I can literally use any rear diff cover out there as long as it is 8.875"? Probably the only thing I'm doing to my rear axle housing for dress-up is throwing a chrome rear diff cover on, and I see most are around $20-25, and come with gasket + bolts. Just thought i'd ask anyway.
On a related note, how do I remove the big, bulky panhard bar mount on the top corner of diff? I can't really see any clear way to do this, there is a rubberized coating on the back side, I think? Nothing given in the Chilton/Haynes/whatever manual I have. I thought about just cutting the rear diff housing on either side and pulling it that way (I'll never use it again), but didn't want to eat up any more cutoff wheel than needed.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 03-07-2008 at 10:57 AM. |
Hollister, CA.
![]() Join Date: Sep 2006
Re: Rear diff covers, panhard stud removal
Here's one I made for a 14bolt....
- - ![]() - ![]() - This particular one was to mount the pivot for a Watts: - ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
can't remember how I got the panhard mount out/off ... but it's possible cause mine is gone. give me till this weekend to get back over to the shop and i'll look at it a bit closer, going from memory here and could be wrong, but I think it's a bolt on affair.
p.s. you'll regret using one of those chrome diff covers ... i haven't seen one yet that didn't eventually leak ... Last edited by Shane; 03-07-2008 at 07:39 PM. |
#4 | |
Seņor Member
Questionable
So, it sounds like powdercoating the original one is the better way to go, eh?
My new axles should be here in 10-14 days. Once they get here, I plan on emptying the pumpkin (probably never had the fluid changed), taking some brake cleaner or kerosene to the guts (per other suggestions I searched), then tossing a better looking cover on. For the panhard mount, it looks like there is a rubberized coating on the back side of it, and it almost looks like it could be a nut. I didn't try to cut it off though to see what's up w/it. I kinda want to keep the provision there - no telling what it could ever be good for, but ...
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#6 | |
Now the 'boss' that's cast into the housing has a nice 'plug' vs. an open hole.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-07-2008 at 09:35 PM. |
1972 Chevrolet SWB
The panhard bar mount on my rear diff wasnt that hard to remove by using a large hammer after the nut and washer were removed. I left the hole for now but for cleanliness may ground it off later.
The truck 12 bolts us a specifc rear cover as long as you get a cover for a Chevrolet truck 12 bolt your golden......oh,stay away from cheap Taiwan chrome diff covers if you can.
My New thread with pics (not my build thread yet.) ![]() http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
I just bought a stock rear diff cover from LMC. To my surprise, it was a genuine GM part. Seemed like it was a heavy gauge steel.
I used a mini sledge and knocked out the stud from mine. It seemed as if it was pressed in because it would not budge and then it shot out like a rocket and almost hit my Dads truck that was in the shop. I just picked up another rear end and did the same thing, only this time the stud came out very easily.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
