Old 03-09-2008, 11:00 AM   #1
NWD02
rear tank filler, please help!
Hey guys,
I just installed the rear gas tank and I'm trying to decide how and where to place the filler neck. I've seen a few behind the tail light and I really liked it. If anyone could please post some pictures I'm desperately needing ideas. I have a steal bed floor so wasn't wanting to put it in the middle of the bed. Thanks for any ideas and pictures provided.
-Nick
NWD02 is offline   Reply With Quote
Old 03-09-2008, 02:14 PM   #2
wibilly
wibilly's Avatar
Re: rear tank filler, please help!
mine is behind the sidemarker
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-09-2008, 06:39 PM   #3
haysonj
haysonj's Avatar
Some one just did this thread a couple weeks ago so you might do a search on it. Here's how I did mine
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 03-09-2008, 06:43 PM   #4
Ironhorse
Ironhorse's Avatar
When I installed my under bed tank I had the some questions and decided to go this route. Not fancy, but quite functional if you still use the truck bed. Really a pretty easy install. Used parts from a early 90's Chev. Lumina Van.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 03-10-2008, 06:22 PM   #5
Psycho71
Psycho71's Avatar
I did mine almost exactly the same way. I use a marine type filler to keep the profile low, and water tight.But the location is almost exact.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 03-10-2008, 07:32 PM   #6
Husker
Husker's Avatar
Here the way I did mine.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 03-09-2008, 08:03 PM   #7
jd4300fel
jd4300fel's Avatar
Here's mine setup for dual tanks.
Mike K
Friend of Bill W
jd4300fel is offline   Reply With Quote
