03-11-2008, 10:16 PM | #1 |
Carrier bearing mount
The mount that the carrier bearing mounts to on my truck rotted out. Does anyone sell a replacement or do I have to hit the junk yard or make my own? Ed
03-12-2008, 12:30 AM | #2 |
Re: Carrier bearing mount
I have one from my 76 that I took off when I put a 1 piece in. Looks fairly simple to make though.
1976 Chevy 1/2T 2wd SWB 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com |
03-12-2008, 02:13 AM | #3 |
There is not much left to mine to use as a template to make a new one, but I'll give it a shot. Ed
03-12-2008, 02:32 AM | #4 |
Ill draw you up one in paint and post it in a little bit.
03-12-2008, 03:01 AM | #5 |
ok, this is very crude, but it should help you out quite a bit. it is made of 1/8" steel plate. you would need to start out with a plate 14"x8" and make the bends, and drill the holes where needed. the holes that look similiar are exactly the same size, thats why only one is labeled. if you have any questions, shoot me a pm. oh, the elongated holes on the top are centered in the top part.
1976 Chevy 1/2T 2wd SWB 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com Last edited by dooce; 03-12-2008 at 03:03 AM. |
03-12-2008, 03:06 AM | #6 |
Thanks alot I'll let you know how I make out. Ed
