Old 03-12-2008, 07:37 AM   #1
David Johnson
David Johnson's Avatar
Shift pointer replacement?
I know this is a stupid question, but can someone tell me if there is a trick to replacing the shift pointer on a tilt column? I can get the old stub out!
David Johnson is offline   Reply With Quote
Old 03-12-2008, 09:06 AM   #2
David Johnson
Re: Shift pointer replacement?
no one?
Old 03-12-2008, 02:39 PM   #3
JimKshortstep4x4
After removing the shift indicator housing, I put the tilt in the lowest position so as to provide a better angle. Then with the pointer assembled into the indicator housing the pointer can be slid into the shift bowl. Once the housing is in position it can be fastened back down to the TS cover. It is a little tricky to hold the pointer in the housing while installing but it will work.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
