Old 03-14-2008, 01:12 AM   #1
koolky
67-72 Addicted
koolky's Avatar
4 speed (SM465) swap?
I have a SM465 and a 250ci in my 68 c20 and i was wondering if it will bolt up to my 307 without a diferent bellhousing?
koolky is offline   Reply With Quote
Old 03-14-2008, 01:15 AM   #2
retselgerg
retselgerg's Avatar
Re: 4 speed (SM465) swap?
pretty sure its the samething...
"OLE BLUE" Goodwrench 350, 5speed, Tilt, PS, PB,
"some guys got into cars for money or girls but i got into cars because of the cars" -Jay Leno
retselgerg is offline   Reply With Quote
Old 03-14-2008, 01:16 AM   #3
tkeduk8r
tkeduk8r's Avatar
You wont need another bellhousing... bolt pattern on the 250 is the same as the 307.... straight six isnt a bad motor though I'd consider keeping it...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 03-14-2008, 08:13 PM   #4
toms68cst
toms68cst's Avatar
You may need a different Clutch Z-Bracket too.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 03-14-2008, 09:25 PM   #5
lilred67
lilred67's Avatar
some of the bell housings with a 3-speed on them had a smaller hole where the input shaft collar went in. when i changed my 3-speed for a sm465 i also had to change the bellhousing for this reason.not all are this way, most do not need a bell housing swap.if you are using your current motor and not changing any of that,the z-bar & linkage will be the same. you will need a high/4speed trans tunnel in the floor board.if you do need a bellhousing the one from the 250 will work.
lilred67 is offline   Reply With Quote
