03-14-2008, 06:31 AM | #1 |
Advice on a '70 GMC 4x4 purchase
I have located a long box '70 GMC 4x4 for an asking price of under 3k. (Would prefer a short box, but long is OK too.) I have attached a few pics. In my pursuit of finding one of these guys, it is hindered by the logistics of finding one near home and availability of a 4x4.
The VIN seems to check out as much as I can find for an original 4x4: KE134ZZ#####: 4x4 half ton from Fremont I think ... is this correct? I took a look a the truck and for the price it seems like it is worth it, but would appreciate any further comments, as it has some issues. The glove box did contained the original owners manual with some sort a metal tag with same VIN and dealership info as well as original owner. The glove box still had an original sticker on the outside for 4x4 instructions. Here is some more of what I noticed: - The wiring is a nightmare of splices everywhere ... an aftermarket A/C that is gone, but bits left over from other things. Several toggle switches drilled into the dash, alarm, A/C, aftermarket auxiliary tanks, Cd player after market stereo nightmare, fog lights, etc. - Two tanks were added at some time on each side, so now three tanks total including the one behind the seat ... and one of the aux tanks was indicated to be leaking when full. - A 4 speed trans., told to me to be original, yet the dash seems to have a column that may have had a shifter there, not sure. - The engine is a Non original V8, told to me to be a 350 with unknown mileage and unknown what it is out of. - The front drive shaft is gone and in the back of the bed as they indicated it needed to be rebuilt. - The frame is solid and very little rust. - The bed is also solid with little rust, but the left rear panel has alot of body "work" as it was indicated to be hit there ... and mentioned something about bending something on that side around the axle. He had it fixed and "bent back" but that side wheel does not sit exactly center in the wheel well. - The door sills have some rust and into the floor pan a little, but not too bad. - Manual drums all the way around. It runs pretty good and the clutch feels good. - The frame rails under the doors are orangeish red for some reason. I asked, but he did not know what that was all about. It looks like heavy overspray, but why orange as he said it was always blue and everything seems to indicate it was. - I jotted down numbers on the frame rail: 3975 198 160 9 1912 Right side 3975 197 160 7 309 Left side I could not find any information on what this means of anything. Any advice or opinions would be appreciated, otherwise I am going to make this one a winner! Thanks. |
03-14-2008, 04:59 PM | #2 |
Re: Advice on a '70 GMC 4x4 purchase
I`ve seen the frames and axles painted that color.That`s how my`72 K/20 is from Colorado.It seems like a good start.You can test the transfer case by jacking the rear and engaing 4wd or unbolt rear driveshaft from transfer case.No sure about the shifter mount on column.It must have been a 3spd originally.Is the option sticker still inside the glovebox door?4spds were an option and would be listed.You`re better off with the 4spd,either way.The wiring...it could be just all the abandoned crap,but an under dash harness is fairly simple to run,if needed.Measure from frame rail to backing plate to see if rear is shifted.It may just be the way the body was repaired or the bed id shifted.I would only be concerned if the difference wasn`t in the body.
I wouldn`t run from the price,but trying for less is best...like $2,500 or so.
03-14-2008, 10:48 PM | #3 |
I'd agree that $2,500 would be a reasonable price to pay from your description and pics.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
03-15-2008, 02:48 AM | #4 |
They call me the Breeze...
First, Welcome to the board!! This is a great place to start if you have questions, or if you just want to hang and meet some pretty cool cats with common interests.
As far as the truck goes, concerning where it was hit, the term ''I had it fixed and bent back" would be a red flag for me. What was "bent back"? The frame? the bed? I would walk away if the frame was tweaked, just my 2 cents. I would try to pry a little more info from the owner regarding that. If the frame is straight, it's prolly worth around $2500, Good Luck, keep us posted.
Mike 69 K20 "Beer is proof God loves us and wants us to be happy"....Ben Franklin |
