Old 03-15-2008, 02:54 AM   #1
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
Heater Hoses
Ok guys dumb ? here. Does it matter where the heater hoses are attached? What I mean here is. The hose that connects to the intake fitting (return I am assuming) does it attach to the upper heater core inlet or lower and visa versa for the other.
Last but not least... if one was going to remove or bypass the heater core for some reason is it necessary to install a bypass hose between the intake and the pump? This is for a small block...
Thanks in advance & God Bless, Terry
77 350 Shorty Wide is offline   Reply With Quote
Old 03-15-2008, 03:20 AM   #2
benoit454
Chris
benoit454's Avatar
Re: Heater Hoses
Well not sure on what goes where but you can just put plugs in the water pump and intake because that's what I done on my monte carlo.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 03-15-2008, 06:34 AM   #3
knightlife
Dark Heart Motorsports
knightlife's Avatar
Re: Heater Hoses
1.) no, it does not matter where they attach. regardless of how they are attatched, fluid will flow through the heater core and exit like normal, it has no check valves built into it
2.) instead of installing a bypass hose, I would personally suggest installing short 5/8 bolts to make a cleaner look (stanless steel, one for the intake, one for the water pump).
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 03-15-2008, 07:52 AM   #4
benoit454
Chris
benoit454's Avatar
Re: Heater Hoses
Well the plugs I used were chrome and had a recessed allen head to it made by spectre, so they looked really good.
Chris
GIT R DONE!!!!!!
