Old 03-17-2008, 03:08 AM   #1
oz's74 project
74 to 87 cab swap
want to swap my old rusty 74 cab with an 87 will my hood fenders match up?
oz's74 project is offline   Reply With Quote
Old 03-17-2008, 03:35 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 74 to 87 cab swap
this will work but youll need to modify the cab some.. first off the cowl needs to come off the 87 cab you need to swap out the wiper arms and linkage from the old cab and you need to use the mounts from the newer cab.. i think you also have to make a hole for the hood bumpers from the 74 on the 87 cab there is also a post about swapping the vin tags
its a pretty easy straightforward swap
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-17-2008, 08:24 PM   #3
low sierra
Old Time Rodder
low sierra's Avatar
Hope part about the mounts is wrong since I just put an 81 cab on my 79. Used new 79 mounts and the fit looks good, just haven't put the 79 fenders on yet. Was told to use original mts by someone in a previous post.
79 GMC SWB Lowrider Stepside [81 cab] that thinks it a Chevy (since 6/1980)
Replacement cab had A/C which now works, made a real truck out of it
84 MC 305 350TH 3.08
4 wheel disc finally
My daily driver again
low sierra is offline   Reply With Quote
Old 03-17-2008, 10:04 PM   #4
oz's74 project
thanx for the advise,hey do you know if my 74 dash will fit in 87cab
Old 03-17-2008, 10:26 PM   #5
low sierra
Old Time Rodder
low sierra's Avatar
I have found that the dash is nearly identical, the pads are interchangeable, but the area where the VIN # is located is a little different. I am going to cut the top left side out of the 79 and weld it in so the vin plate and left most dash pad hold down will work right. The other side seems to be identical except for the hole that holds a speaker which can be used both sides if you use an 81 up dash pad which won't require dash mods except for VIN plate.
