Old 03-17-2008, 05:07 PM   #1
don t. - 72gmc
Why wont it fire?
Yesterday was my grand daughters b-day and I just hadda drive the 70 GMC for the 1st time this year. Checked fluids, all looked good. She fired right up. Drove around for 15 miles or so. Tranny was a little low, topped it off. All looked good, off went me and the wife. About 50 miles later, at a stop light, the truck started bucking abit. Threw it into neutral to keep her running. Never did die. Had to make 1 stop on the way, fired right up, things didn't change. Made it to the party. Went to leave was the same. My SIL said stop by and we'll fix er up.
Cleaned up the points, made it worse. It fired but was bucking worse than b/4. Cleaned points again, back to original condition. Went to the local AutoZone, which was a joke. Besides not having a clue, parts were not in stock. They did give me directions to NAPA. I bought a dizzy cap, points, rotor, condensor and a ballast resister. Replaced all but the ballast resister. Truck cranks real well but does not fire. Pulled cap, rotor does spin. Pulled coil wire to dizzy and grounded to block. Little or no spark. At this point, I didn't have a multimeter to check volts. SIL handed me his keys and said see ya tomorrow.
While lookin around I noticed....
....black wire into dizzy has a flat spot, kinda like it got caught under the cap. It doesn't look cut but???
....There is a condensor on one of the coil posts. This is inaddition to the condensor under the dizzy. What's this for? Don't remember ever seeing one there b/4. Sorry, don't remember which post.
....Is there a ballast resistor? I am unable to locate something that looks like what I bought. My other truck is a 72 GMC 2500, but its HEI and aint got these parts.
Things you'll prolly need to know....problem truck is a 70 GMC 2500 400BB w/a 4-bbl q-jet. Auto trans w/factory ac. Coil is stamped as 12v, use w/external resistor. 93,000 miles on original engine. Truck appears to be original, no mods that I can tell. I did show it off to y-all about 4-6 weeks ago. I would have attached a link, but Im at home currently connected at 19.2K, and its taken me about 30 minutes to get this far. The dog needs to go out. I'll try and find my prior post and reply back.
FWIW....4 of the 5 parts I bought from NAPA had "Made in the USA" on a sticky label on the box. All were Echlin.
Thanks inadvance for your time.
I do appreciate it.
Have fun.....don t. .....
don t. - 72gmc is offline   Reply With Quote
Old 03-17-2008, 05:29 PM   #2
hilljob26
hilljob26's Avatar
Re: Why wont it fire?
you really ought to get a hei,these babys are on ebay for 45 bucks,and they are really nice as well,other then that,i think you have a dist. issue
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 03-17-2008, 05:44 PM   #3
LONGHAIR
Just from what I see in you post (assuming the that points are ok) I would look at the coil itself. If you get little/no spark from there....it doesn't really matter what is going on downstream. T
Radio noise suppressor
LONGHAIR is offline   Reply With Quote
Old 03-17-2008, 06:16 PM   #4
don t. - 72gmc
Prior post w/pics
Thanks for the info so far. HEI is prolly in my future, but hoping to "cheap out" at this point. I plan to test volts to the coil. I agree it may be bad.
Here is a prior post that contains pics of the truck.
Hope this works..... http://67-72chevytrucks.com/vboard/s...d.php?t=274880
Im about ready to leave. SIL has DSL, so I can check from there.
Thanks. I do appreciate it.....don t. .....
Old 03-17-2008, 06:34 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Lots of things that can cause the symptoms you gave... Gas problems-moisture, old gas, etc. Ground cables- Battery, engine flat ground cables. Make sure they have good solid, clean connection.
Ignition. Look like you've taken care of preliminaries. I usually work myself backwards starting with spark to the plug, then remove cable at dis end and see if spark jumps to the cable. One thing to remember-you can't always tell if the spark is good by looking at it.
A weak or defective battery can give you a weak spark so make sure your battery is at optimum and that your alternator is charging at the correct rate when running. If the battery is bad and alternator not charging properly, your truck will have those same symptoms you describe.
Let us know what you find.
68gmsee is offline   Reply With Quote
Old 03-17-2008, 07:00 PM   #6
67_C-30
I have a radical idea!
67_C-30's Avatar
I'll offer three suggestions:
H
E
I
Seriously, I would replace the wire you said that is flat. The wires could be broken inside. Also, check the point gap and dwell with a meter. The point gap should be .018" IIRC. The next thing was be the coil wire connection and possibly even the coil.
With that being, I really would swap it over to electronic ignition. If you want to reatin the stock distributor, you can buy a kit from Pertronix and others that just replaces the points.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 03-17-2008, 07:37 PM   #7
DREAMS OF A 67
Step Brother
DREAMS OF A 67's Avatar
Since you have already bought all those parts, I would check the voltage from ignition switch.(+ side of coil) If that is good I would change the coil. A bad coil will most of the time give trouble after it gets warm.
DREAMS OF A 67 is offline   Reply With Quote
Old 03-18-2008, 12:01 AM   #8
El Jay
Gone to greener pastures
I'd lean toward the coil starting to go south, especially since you've replaced everything else.
Also, if my memory serves, the extra condenser on the coil is to reduce ignition induced radio interference.
BTW, I also agree with all the pro-HEI guys. That's definitely the way to go.
Good luck.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 03-17-2008, 07:40 PM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Hi Don t
First I want to commend you for a very detailed post. I don't see many as descriptive as yours and it makes it easier to find a solution. All the posters have given good responses so I will add mine.
GM quit using the ballast resisters in 65 or 66 and went to a resistance wire in the harness from the key to the coil. You should have a yellow or orange/purple wire from the starter solenoid "R" terminal to the coil positive connection to supply 12 volts when cranking. Otherwise the engine may not start or will start hard. Be sure you have the coil wired correctly or you will get the symptoms you are having. Setting the points is critical so be sure you have them on the highest point of the lobe and set at .019.
Here is a very good site for points ignitions.
http://abbysenior.com/mechanics/ignition.htm
You did remember to put the rotor button back on? LOL.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-17-2008, 11:44 PM   #10
Luvlegs
Luvlegs's Avatar
If you haven't found it yet - mine had a quick non-start, retired and it fired up - went down the road and started smoking under the dash - I actually had a MAJOR short where the harness runs over the inner fender behind the hinge area- no telling how long it was there until it acted up.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 03-18-2008, 03:01 PM   #11
don t. - 72gmc
Thank you.
Its a Monday morning sick day for me. I got 12v at the coil, battery may be at bit low at 12.82v. Made sure everything I did day b/4 was ok. No change. Got a new coil, no change. I went to call for a rental trailer, forgot my receiver at home. Good side..wife and I got to see the daughters family.
I follow up later when its fixed. Might not be for a while.
Thanks again.....have fun.....don t. .....
