14.1 @ 96MPH
Restore?
Anyone ever actually used Restore in their engine and seen an improvement? I'm going to dump a can in next time because while I'm not losing much oil and my compression is fine, I know the rings are having a hard time dealing with 10.0:1 compression...
Project1970 - LS1 Swap Complete! ![]() |
I've never used it before, but I have a *really* hard time dumping miracle crap into my engine. If it sounds like snake oil, it probably is... Plus, it makes me nervous as to how it "restores compression". I wonder what kind of sludge/gunk is in it that will either stick to my cylinder walls or to my pistons, or to my rings. The same sludge is going to stick to my bearings, oil galleys, valves, tops of the pistons, etc...
I view it in the same catagory as that "Aluma-seal" crap for radiators.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
![]() Join Date: Aug 2001
Don't use Restore. I had a head go bad 100 miles after using it and a friend lost his motor. No good~!
Your not burning oil, and your compression is fine. What makes you think that you're rings are having a hard time with 10:1 compresion???? 10:1 isn't that high, although you probably have to run premium.... I would leave everything the way it is...
Rudy Fierros '95 Honda VFR750F Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it! |
14.1 @ 96MPH
Mass quantities of blowby. It took one PCV to carb vacuum, one filtered breather on a PCV valve, and one unfiltered, unvalved breather before it stopped trying to push oil out of the filtered breather.
