Old 03-21-2008, 08:57 AM   #1
71Custom10
71Custom10's Avatar
Brakes?
I recently replaced all my stock rubber lines with braided stinless steel lines. Bled brakes several times but still no brakes. Found a clogged rear wheel cylinder, replaced both, still no brakes. Pluged lines from m/c to check it and no good. Bench bled m/c, reinstalled with lines still plugged, still no good. Had a booster and m/c from 89 burb on the shelf in the shop, so i decieded to make the swap. everything installed and looking much better than the stock setup, plugged lines from m/c and it checks out ok(bench bled it prior to install also). Hooked up brake lines and bled the system several times. I now have brakes but the pedal is very soft. It feels like there are no brakes at all but the truck stops fine. I would prefer a little more stiffness in the pedal. Brakes were fine before I decieded to replace the rubber lines, they were looking pretty bad. Please help, I'm starting to lose my mind.
'72 1/2 ton disc/drum Thanks
71Custom10 is offline   Reply With Quote
Old 03-22-2008, 03:32 AM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Brakes?
Wish I could help; here's a bump for you though.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 03-22-2008, 03:56 AM   #3
ed2552
ed2552's Avatar
Re: Brakes?
how are the hard lines? my 67 has no rear brakes, i have a crack or split somewhere, fluid just pours out of rear when pedal is applied
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-22-2008, 04:28 AM   #4
71Custom10
71Custom10's Avatar
Re: Brakes?
hard lines seem good. I can't find any leaks and I don't seem to be loosing any fluid from m/c. thanks for the bump
'67 Chevy Longbed Fleetside - Daily Driver(For Now)
'72 Cheyene Longbed Fleetside-Daily Driver
Best Towing Service
Old 03-22-2008, 05:07 AM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Brakes?
I'm sure you checked this,but did you adjust the shoes out after drum install?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 03-22-2008, 06:48 AM   #6
71Custom10
71Custom10's Avatar
Re: Brakes?
I did adjust the drums but i'm going to check them again tommorrow. I think one is to tight, drivers side rear wheel locked up yesterday.
Best Towing Service
Old 03-22-2008, 05:42 PM   #7
Andy4639
Old member
Andy4639's Avatar
Re: Brakes?
Just thinking out loud here.
You hooked the master cyclinder back up to the right line right.
You may want to bleed them again and maybe flush out the system good if it was clogged up at one point.
Any mositure at all will cause all kinds of problems. If the fluid is over a few years old I would flush it good.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-22-2008, 06:00 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Re: Brakes?
If brakes feel mushy but still stops you could still have some air in the system somewhere. You may have air in the front or rear sides. Not enough to prevent you from stopping but enough to feel mushy.
Here's a simplified site on how stuff works describing what I'm referring to. I like to use it because it has pretty decent graphics. If you scroll down and click the red arrow, you can see that a leak (as in this case) or air may allow extra travel of the primary piston.
http://auto.howstuffworks.com/master-brake1.htm
Another possibility is that the master cylinder primary piston is allowing some fluid to flow back into the the reservoir past the seal.
I've had to replace new master cylinders several times before finding a good one. In one case, I finally asked for my money back and went to a different auto parts and got a different brand.
Forgot to add... This was on one of my newer trucks not my 68 or 69... But still could apply.
68gmsee is offline   Reply With Quote
Old 03-22-2008, 06:03 PM   #9
Eddie47
Eddie47's Avatar
Re: Brakes?
Have you checked the Proportioning Valve? Had a similar problem and the Proportioning Valve fixed it .
Good Luck
Eddie47
Eddie47 is offline   Reply With Quote
