Old 03-21-2008, 04:03 PM   #1
muddyole 69
wtb auto shift linkage need some info as well
I have a 72 truck with tilt and the trans is a metric style 350 turbo the linkage is not working right and binds. Is there a difference between tilt and non tilt linkage ? I have nothing to campare to as all my other trucks are standard. I just need quick idea of what if anything I can do to fix this also are the linkages the same for the 72 as say a 78 ? I do have a 78 parts truck that I could rob parts to make this go but I was hoping for someones expertise to save the day with a nugget of wisdom. thanks Mike If none of the aforementioned things will fix this I need a complete linkage setup to make this a functional truck again lmk mike
hav'n fun be'n me
muddyole 69 is offline   Reply With Quote
Old 03-21-2008, 04:25 PM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: wtb auto shift linkage need some info as well
Mike,
Not really sure if theres a difference between tilt and non-tilt linkage but I recommend someone - check with board member (teeitup, a.k.a. Randy) he's also a site vendor. He should be able to answer your question and most likely has a good, used linkage for sale.
Good Luck
Harry
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 03-21-2008, 05:28 PM   #3
muddyole 69
thanks Harry will give Randy a try mike
hav'n fun be'n me
Old 03-22-2008, 02:38 AM   #4
JimKshortstep4x4
Transmission linkage is the same for tilt and non-tilt columns. After 72 the linkage was changed.
On the binding, I would make sure that the linkage on the tranny is upright.
Here is a pic of the linkage that one of the board members posted which shows how the linkage is assembled.
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
