Old 10-28-2002, 11:32 PM   #1
Primered_69
Primered_69's Avatar
Power booster question
Will the valve and master cylnder from a nonpower brake sytem work on a booster equiped truck?
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 10-29-2002, 12:16 AM   #2
racedvl
racedvl's Avatar
I think it depends on the year, but as far as I know the master is diffrent, but if you are not converting the drums to disk, I would think the valve is the same.
racedvl is offline   Reply With Quote
Old 10-29-2002, 01:00 AM   #3
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
I have a 70' and I just changed over to power
brakes. I changed the master cylinder for $18, Im not sure If I needed to, but the parts dude suggested it...
Power is a massive step upwards!!
Drums gotta go next........
Good Luck
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 10-29-2002, 08:03 AM   #4
JimKshortstep4x4
Smile
The master cylinders are different because the piston on the non-power has a shallow hole where the rod fits and the power master cylinder has a deep hole. You should be ok on the valve unless changing to discs.
Jim
Old 10-30-2002, 12:01 PM   #5
trukman1
M/C piston recesses
Careful about the deep vs shallow m/c piston. I have a dual diaghram power booster that has the short rod, therefore using the shallow piston booster. The unit came off a '72 Suburban. My other single diaphram boosters are the deep style. Incidently, there were two different "deep" pistons produced and one shallow version according to the GM manual I have.
trukman1 is offline   Reply With Quote
