Old 03-25-2008, 05:38 AM   #1
70c10
67-72 Addict!
70c10's Avatar
Questions about a 58' Apache
My buddy is looking at a 58' Apache and asked me a few questions about disc brake kits and 5 lug axles for the rear. I'm not very familiar with these years. Where should he get a disc kit and what vehicle can he get the rear 5 lug axles from?. Last question is who sells a patch panel to hide/remove the spare tire indentation?. Thanks!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-25-2008, 05:47 AM   #2
entourageguy
Yellow truck club
entourageguy's Avatar
Re: Questions about a 58' Apache
I've put a 1999 S-10 4x4 4 dr axle works good.
Already had discs on it.
Rear fender is best to buy new rather than try to patch.
we like pictures.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 03-25-2008, 05:55 AM   #3
70c10
67-72 Addict!
70c10's Avatar
Thanks Brian, right now he's trying to see if it's worth getting. You are probably right about the fender. Any other options on rear axles for 5 lug? What about front disc kit?.
Jim
Old 03-25-2008, 06:26 AM   #4
entourageguy
Yellow truck club
A quick look on CPP web site found this.
http://www.classicperform.com/Store/...s/4759DBK5.htm
others will chime in on your question.
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 03-25-2008, 06:30 AM   #5
hotrodsbyray
if that truck is a short wheel base, i would love to have that rear fender and the brackets to mount the spare tire on the side! i would trade my fender for those if what he has is in good shape. OR, i just happen to have the brackets and parts to switch to front disc brakes and also add power steering, if he might be interested. i just put trans am clip under mine so i dont need those parts.
can give me an email to hotrodsbyray@yahoo.com if he would like to do any swapping - same goes for any body else that has a good spare tire fender and brackets for a short step side. also have good original front axle with springs and brackets if that would sweeten the deal or if anybody needs them.
hotrodsbyray is offline   Reply With Quote
Old 03-25-2008, 08:09 PM   #6
70c10
67-72 Addict!
70c10's Avatar
Thanks again Brian!
hotrodsbyray- He doesn't own the truck yet will give him your info in case he gets it. Thanks
Jim
Old 04-04-2008, 05:13 AM   #7
Caveman49
I purchased the conversion bracket kit from CPP on this link http://www.classicperform.com/4754chevtrk.html 4759DBK5 5-Lug on 4-3/4" Bolt Pattern Disc Brake Bracket, kit. Cost around $105 shipped, and use rotors and calipers off one of my 74 El Camino parts cars, they bolted right up to it. I did put new bearings and seals in the rotors....
Caveman49 is offline   Reply With Quote
Old 04-04-2008, 04:48 PM   #8
xakk
xakk's Avatar
There was an article in Classic Trucks a few months back where they were using the 10-bolt posi rear out of an 81 Trans Am. Supposedly it was the same width as stock but with discs.
xakk is offline   Reply With Quote
Old 04-04-2008, 06:22 PM   #9
1-ton of fun
polishing a turd
1-ton of fun's Avatar
it should be.
i am using a 77 nova 8.5" 10 bolt rear with 12" discs from a 98-02 f-body. the brakes bolt right up, just switch the brackets side to side (put the right on the left, and left on the right) and only cost $200 on ebay.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
