03-28-2008, 04:16 AM | #1 |
72 arms and spindle fit?
Ok I was going to do the whole crossmember then decided not to so I took the upper\lower control arms and spindles off a 72 and when I took them apart to clean them up the lowers are shot so my question is can I use the uppers and spindle from the 72 on my 65's dropped lowers? Can I run the same balljoint or ream the spindle to fit? I've done a search but I've never really found a direct anwser to my question. Thanks.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
03-28-2008, 04:44 AM | #2 |
A guy with a truck
Re: 72 arms and spindle fit?
I wouldn't try to ream the spindle. Just use the '72 lower balljoint. You will need to adapt the tie-rods as well...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
03-28-2008, 04:58 AM | #3 |
Ok I can do that a balljoint is cheaper than a lower arm. I plan on using all the steering stuff from the 72 draglink,tierod ends idler etc. Thanks
