03-31-2008, 02:23 AM | #1 |
Head help
Trying to decide which heads to go with. I could use a little help. L98's or Vortec. Personally I think the Vortec's are the way to go but I can get a set of L98 for free. If anyone has any experience please let me know. They are going on a 350 w/mild cam, Edel intake manifold, Edel 600 carb, and a set of headers. Will i need more CFM?
'72 Chevy C10 383, 700r4, 3.73's A little rust never hurt anyone. I consider it weight reduction. |
03-31-2008, 03:08 AM | #2 |
Re: Head help
The l98 is a good head esp. if it is free but the vortec flows better in my opnion. but you will need to buy a new manifold also
67' C-10 Project Truck Clinton Township MI My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=287690 |
03-31-2008, 05:55 AM | #3 |
Re: Head help
Vortecs significantly outflow the L98 heads and have a better chamber to boot.
If they're free and overhauled, that's a good deal and I'd take 'em for a mild build (< 1 HP/CID). |
03-31-2008, 06:42 AM | #4 |
Re: Head help
I take it that vortec is the way to go. Best intake manifold for the money?
03-31-2008, 04:56 PM | #5 |
Re: Head help
Edelbrock air gap is the best in my opinion - best flow best air temp charge
03-31-2008, 05:13 PM | #6 | |
Re: Head help
IMHO, the air gap thing is marketing hype. I've seen NO back-to-back dyno results that show any benefit at all. |
03-31-2008, 06:49 PM | #7 |
Re: Head help
I assume different headers are required also?
03-31-2008, 07:20 AM | #8 |
Re: Head help
Unless you're planning to turn > 5000 RPM on a regular basis, the Performer or Performer EPS are the best choices.
Your name is pink because you haven't paid for your membership |
04-01-2008, 03:06 AM | #9 |
Re: Head help
Nevermind, I found out that the exhaust ports are the same as far as pattern for the headers is concerned. Thanks for all the help!
04-01-2008, 03:25 AM | #10 | |
Parts and more parts
Re: Head help
04-01-2008, 04:00 AM | #11 |
Re: Head help
I don't know how a head can have an "HP peak", but the FLOW on the L98 head levels out at a little over .400 lift @ 189 CFM (.500 to 199 CFM) - which is pretty poor. The stock Vortecs are making 216 CFM and 229 CFM respectively at those lift levels.
Note that using 1.6 rockers on a Vortec means buying upgraded versions - the stock Vortecs are lift-limited to .475, and a cam that would fit within that range with 1.6 rockers likely wouldn't have the duration or overlap you'd look for. I'd stick with the stock heads, the GMPP CHEAP self-aligning 1.5 stamped steel rockers and a cam of less than .475 lift and call it good. |
04-01-2008, 04:50 AM | #12 |
Re: Head help
Thanks for all the info! I really appreciate everyone's help on this one. Vortec it is
