Saving 1 truck at a time!
Rotting vibration dampener!
So what do you do with the rotting vibration dampening material between the hood skin and support ribs? This stuff was installed with some kind of black goo and now it is crumbling and falling out. I am sanding the underside of the hood in preparation for a new paint job. How do you get this stuff out and what do you replace it with?
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
You can buy the replacement sponge rubber from the vendors. I think most of them handle it, but for sure LMC. I use mineral spirits and elbow grease to remove the old adhesive and rubber.
Jim |
SKINNY TIRES RULE!
The PO of my truck used canned foam isulation
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Thanks guys, I was not sure if I should even be concerned about it but I hate to just leave it. I really hate to glue an ugly mass back in there...I might try a thicker closed cell foam that will not show under the support but still provide the needed support.
its all about the +6 inches
WOAH!
You mena there is supposed to be something in there!!!???? J/K...I knew that. There is actually a little bit of remains in the hood of the GMC. I know it had all burned away in a carb fire on the first longhorn. Carb fires suck. |
14.1 @ 96MPH
Mine were COMPLETELY gone...I just got some new ones from Rick's Pickup Parts and shoved 'em in, heh. Not quite lined up but not glued either, they fit just fine...
Project1970 - LS1 Swap Complete! ![]() |
Ain't we cute?
Dynamat! I'd use some xtreme plus hoodliner (or the generic equivalent).
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES! FOR SALE $3900 ![]() |
![]() Join Date: Feb 2002
I got a new one from a machinist for 140 bucks. He said it was made in Australia. I wouldn't f^ck around with just glueing back together an old one. It could come off while underway and either blow thru the radiator or cut into the timing cover.
