Old 04-02-2008, 07:25 AM   #1
playinsafe44
1970 gmc 1 ton dually wheels
my dad just got a sweet deal on a couple of trucks. a '73 mustard yellow 1/2 ton (250 I6, original with 60,xxx miles), and a '70 gmc 1 ton dually, flatbed with a 350, granny 4 spd, and nice flatbed. he bought them both for 500 bucks. we drove them away, the 73 is cleaning up real nice, but the 70 will need a little more tlc. right now we are looking to get some better wheels for it. the ones on it have some pretty serious rust. what are our options? i thought the eagle alloys 16 inchers would work, but them i was told that i cant run them on the inside rear, and then les schwab told my dad that he would need wheels custom made. so any suggestions would be great for wheels
playinsafe44 is offline   Reply With Quote
Old 04-02-2008, 10:09 AM   #2
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Re: 1970 gmc 1 ton dually wheels
I put a set of Weld wheels on mine. Ran the old split rims on the inners. With the 70 you can run later 70's drop center rims for the inners as the bolt pattern is the same.
First picture stock rims
Second picture the Welds
oldiron is offline   Reply With Quote
Old 04-02-2008, 11:36 AM   #3
72armyswbtruck
72armyswbtruck's Avatar
Nice looking truck,
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-03-2008, 03:18 AM   #4
Cyclone44
Step Brother
Cyclone44's Avatar
Originally Posted by 72armyswbtruck View Post
Nice looking truck,
That is sweet...
Cyclone44 is offline   Reply With Quote
Old 04-03-2008, 03:36 AM   #5
playinsafe44
im sure theres more people running around with duals. theres a black 1 ton somewhere on this website that is just beautiful, it has modern wheels similar if not the same as those welds. im just trying to find out the easiest and nicest way to go with the wheels. eventually this will be fixed up and looking like a new truck again, the perfect parts and wood hauler!
Old 04-04-2008, 06:57 AM   #6
67_C-30
I have a radical idea!
67_C-30's Avatar
I think you would be talking about this '68 owned by JoesJunk.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 04-04-2008, 07:02 AM   #7
67_C-30
67_C-30's Avatar
BTW, Here's my cheap but decent looking set-up on my '67 C-30 dually pickup. They are standard 16" steel wheels with '97 Chevy C3500 trim rings and center caps. They do require special lug nuts with external threads to hold the caps on.
My '67 C-30 came with 17.5" wheels and my '69 C-30 ramp truck came with 16" 2 piece wheels, but regular 16" rims clear the drums with no problems on both trucks. Some 73+ model trucks that came with 16.5's, I know 16's won't claer those drums. I think with your '70 you can run any 16" wheel you want with no problems.
My trucks
Old 04-02-2008, 02:26 PM   #8
I ran `71-up chrome budds on mine with painted budds for inner rears.The only problem was the pre-71 drum brake trucks use 1/2" studs/lugs and the later trucks use 9/16".Also,the 1/2" lugs are flat back castle-style and the later 9/16" are beveled and use a spreader ring to seat into.I drilled my drums,pressed 9/16" studs,and chamfered the wheels to eliminate the need for spreader rings.That worked out fine dispite what all the nah-sayers said about keeping centered,loose fitting studs,and all the other blah blah blah.
Old 04-02-2008, 10:54 PM   #9
playinsafe44
those welds are pretty much what we are looking for. so you have to use a stock steel for the rear inners? i love that truck of yours old iron, we plan to haul a LOT of wood with it
Old 04-03-2008, 02:27 AM   #10
IAFF2407
IAFF2407's Avatar
Oldiron, everytime I see that truck I fall in love again.
1972 GMC Sierra
1972 GMC Super Custom Suburban
IAFF2407 is offline   Reply With Quote
Old 04-03-2008, 04:45 AM   #11
tcb-1
Nothing to see here.....
tcb-1's Avatar
x2!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 04-03-2008, 05:28 AM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
oldiron... that thing is beautiful!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-04-2008, 03:37 AM   #13
playinsafe44
so would i have to drill the drums and install 9/16 studs to be able to install modern wheels? and even then i still have to run the steel inner rear?
Old 04-04-2008, 06:36 AM   #14
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Yes you will have to drill and insatall 9/16" wheel studs and most all aftermarket budds require the use of the stock type inner steel wheels to remain hubcentric.
Heres a pic of my 72 that I run American 19.5s on.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 04-04-2008, 03:06 PM   #15
As mentioned,once these trucks went disc brakes in`71 the stud size increased from 1/2" to 9/16".Drilling and installing the larger studs is one option and another wouldbe to swap the front to disc brakes and use a `71-up rear.
Old 04-04-2008, 10:00 PM   #16
playinsafe44
joesjunk '68 is the truck i was talking about. thats the type of wheel we want to put on. 67_c-30, did you convert your studs to 9/16th? and those are more modern steel wheels right? i like your wheels and the trim rings really make them look great. swapping to disc brakes and installing a different rearend seams like way to much work a wheel upgrade. and is everyone that has a pre 71 dual with non stock wheels either swapped to discs and a newer rearend OR drilled their drums?
Old 04-06-2008, 05:21 AM   #17
playinsafe44
anyone?
Old 04-06-2008, 07:10 AM   #18
67_C-30
67_C-30's Avatar
I changed the lugs on my '67 C-30, but I didn't on my '69 C-30 ramp truck. I am running newer style 16" wheels and tapered seat 1/2" lug nuts (the factory ones were flat). I have been running it like this for years with no problems.
My trucks
Old 04-06-2008, 08:28 AM   #19
rambler
MOVE OVER
rambler's Avatar
subscibing to the thread.. love the pics and someday I've got to a C30!
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 04-06-2008, 05:37 PM   #20
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you guys think old iron's truck looks good, you should see it in person.
Old 04-06-2008, 08:23 PM   #21
playinsafe44
does it seat nice and tight just using tapered 1/2 inch lug nuts? we plan on taking this thing back and forth from portland OR to boise ID and i dont want to worry about the wheels vibrating, braking studs off, or anything esle serious. and if anyone has had their studs changed over to 9/16th, how hard was it? can you do it yourself, or is it something a machine shop should handle? thanks for all the info, i just want to know the options/risks
Old 04-07-2008, 01:17 AM   #22
67_C-30
67_C-30's Avatar
Its easy to change them, and you can do it yourself. You have to knock the studs out and open up the holes with drill and tap the new ones in. However, I went to a parts store and found some 1/2" lug nuts that used a 7/8" lug wrench to take them off. Most have a 3/4" or 13/16" outside hex, but the ones I got have bigger tapered seat. They seat vey good and I have have had no problems with any vibration or coming loose for over 5 years now. As you tell below, I this truck has been no stranger to a load duriung that time!
My trucks
Old 04-07-2008, 06:42 AM   #23
playinsafe44
ok so im thinking ill just get the wheels we want, and then figure out if we can get away with using some different tapered lug nuts, or installing 9/16th wheel studs. all the pics are great by the way! i would love to get a set of the steel wheels like you have on your dually/fleetside and the beauty rings and caps. thats just a real clean look. what would i get those off of? the welds are the coolest, but i should hold off on them until im 100% sure on how to install them.
Old 04-07-2008, 08:37 AM   #24
67_C-30
67_C-30's Avatar
My wheels came off of a '97 C3500, but you could use any 16" Chevy rims from the mid 70's up to about 1999.
My trucks
