Old 04-04-2008, 07:59 AM   #1
SRH916
1975 C-10 Silverado LWB
SRH916's Avatar
Talking I Love My Truck. (Help hooking up)
It's so much more fun to drive than newer cars. But one thing I would love it to do is to hook up a little bit better. Its always fun to show friends up by just peeling out like its nothing, but its also nice to get off the line fast instead of just roasting the tires... Any help for getting my truck to hook up a bit better? Oh, its a 1975 C-10 LWB "BIG 10" 350/375/gears unknown.
Thanks in advance,
Jared
1975 LWB C-10 Silverado
- Stock
- "BIG 10"
- 4 Bolt 350 "Brand new" 1200mi
- THM-375 "Brand new w/trans cooler" 5000mi
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
SRH916 is offline   Reply With Quote
Old 04-04-2008, 08:09 AM   #2
f.monroe
f.monroe's Avatar
Re: I Love My Truck.
Install a posi carrier . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 04-04-2008, 09:00 AM   #3
streetstar
streetstar's Avatar
Cal Trac traction bars will help a ton -- they keep the leaf springs from winding up so much
Frank's suggestion of installing a posi carrier is solid too unless you alredy have one (does it leave one black stripe or two?)
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 04-04-2008, 09:17 AM   #4
SRH916
SRH916's Avatar
I've got 7 leaf springs in the back, if I get rid of some, will it allow it to bring the back down for a bit more traction right?
- Stock
- "BIG 10"
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
Old 04-04-2008, 06:58 PM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
it might a little, wide tires like 295 or 305 would help it hook, also traction bars.
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-04-2008, 08:06 PM   #6
swb85
On a budget like Fred Sanford
swb85's Avatar
Get a posi, traction bars and decent tires. I've got a locker, lakewood slapper bars and 275/60/15 BFG T/A's and hook ok with a 450hp 383 & 4 speed.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 04-04-2008, 08:36 PM   #7
SRH916
SRH916's Avatar
Do those traction bars help alot? I just looked at them, and they seem to be a reasonable price.
- Stock
- "BIG 10"
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
Old 04-04-2008, 09:52 PM   #8
swb85
swb85's Avatar
They helped quite a bit with traction, but more importantly they eliminate wheel hop.
Old 04-05-2008, 07:46 AM   #9
SRH916
SRH916's Avatar
Where should I look to get a posi?
- Stock
- "BIG 10"
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
Old 04-05-2008, 04:37 PM   #10
swb85
swb85's Avatar
Depends how much money you want to spend. I have a richmond powertrax locker in mine, was $300 from summit. Clutch type posi's will run you $400+.
Old 04-05-2008, 07:54 PM   #11
SRH916
SRH916's Avatar
What would be the problems with running a detroit locker on the street?
- Stock
- "BIG 10"
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
Old 04-05-2008, 08:29 PM   #12
84 400
Sb 400 club
84 400's Avatar
In wet and slick conditions they can get a bit hairy. On ramps can also be a pain when you hang it side ways. But you will get used to the limits of it very quick.
Aside from the locker wanting to throw the rear one way or the other tire wear increases. Personally I like lockers because they don't wear out like Posi but the posi is more streetable.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 04-05-2008, 08:33 PM   #13
SRH916
SRH916's Avatar
Thanks for the explanation. How much should I expect to spend on a decent locker? And is there a different gear oil for each? Open carrier, posi, locker? I have NO experience with differentials.
- Stock
- "BIG 10"
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
Old 04-05-2008, 09:08 PM   #14
swb85
swb85's Avatar
Expect to pay a touch over $400 for something like a Detroit Locker, then you'll have to pay someone to set it up for you. The powertrax lockers like I have in my truck are about $300....they install inside your stock open differential with hand tools. 84 400 is right though, you need a fairly loose definition of "streetable" if you want a locker on the street. I've got the powertrax locker in my truck (10 bolt, 3.42) and a Detroit Locker in my camaro (9", 4.56). They do want to kick the rear sideways at times, especially while shifting a manual trans vehicle. They also make quite a bit of noise when they unlock around corners. Both of those characteristics are much less pronounced in auto trans vehicles though, mine are both manuals. You never have to worry about burning up your posi though.
EDIT: Open carriers and lockers will just run straigh 80/90 or 85/140 gear oil, most clutch type posi's will need a friction modifier additive in the gear oil.
Old 04-05-2008, 09:37 PM   #15
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Do not remove leafs for better traction....it'll make wheel hop even worse.....
Traction bars will only help if you already have a problem with wheel hop....a posi would be the best investment...like an Eaton, as they are a clutch type and are rebuildable.
Detroit$ are tough, but noisy, and are sketchy on slick roads, or if ya snap an axle....
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
