Old 04-05-2008, 07:14 AM   #1
GmcSS
GmcSS's Avatar
Front bumper brackets help?
I think this has been covered before yet i cannot find it. I am having troubles mounting my front bumper the drivers side bracket is hitting the power steering gear box... Do I need to cut the bracket??? If so anyone have a photo of how much should be cut?? Sorry if this is a repost.
GmcSS is offline   Reply With Quote
Old 04-05-2008, 07:33 AM   #2
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Re: Front bumper brackets help?
Did you buy an after market bracket? It should miss our box, im sure someone will chime in.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 04-05-2008, 04:16 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Yes, I think it needs to be notched on some year trucks. I don't know how much.
By the way, welcome to the board from Iowa.
LockDoc
Leon
Old 04-06-2008, 09:55 PM   #4
GmcSS
GmcSS's Avatar
I had the brackets switched.....fix the issue when i changed them to the right side
Old 04-07-2008, 12:35 AM   #5
72armyswbtruck
72armyswbtruck's Avatar
See you had it in you the whole time
BTW from Idaho
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-07-2008, 04:38 PM   #6
Rod
There are a few differences between the applications. For example a 67 bumper bracket on drivers side typically was not recessed for the PS box as PS was a different style and used a different box than a PS box..67 used ram assists PS.
68-72 2 wd GMC should be the same.
68-70 2 wd Chev should be the same as the 68-72 GMC 2wd.
4x4 are unto themselves and 68-72 gmc 4x4 are same as 68-70 Chev 4wd.
4x4 71-72 chev are their own style also...longer due to signal lights in bumper.
You may run into brackets that dont have a recessed clearance for the PS box because the truck was shipped with brackets not originally ordered with PS option.
Rod
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-07-2008, 07:06 PM   #7
GmcSS
GmcSS's Avatar
Rod
The Brackets came of a 71 gmc with ps, and went on a 68 with ps. Thanks for so much info it is great to know!!
