Old 04-06-2008, 01:28 AM   #1
hughnews1
1968 gmc 3/4 with Leaf Q hellp
my install shop found the back leaf shakcles bad .. so I bot new ones 29.95 local .. now he sez need the brackets to hold them .. does anybody make them ? .the spring shop sold my some Ford brakcets .. said drill new holes and used them ... what should I do ????
hughnews1 is offline   Reply With Quote
Old 04-06-2008, 02:14 AM   #2
Mike C
Mike C's Avatar
Re: 1968 gmc 3/4 with Leaf Q hellp
The rears? You might be able to get lowering ones for a 73 and up truck. Does yours have 2 1/4" or 2 1/2" springs? 2 1/4" more common, but Longhorns and 4x4's have 2 1/2". Junkyard probably your best bet.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-06-2008, 03:09 AM   #3
I think you`ll have the wider ones in`68?You could drill for the Ford brackets.But,if time isn`t so tight,try to find the originals.See if any are being parted in the parts section.If you want to lower,then the lowering brackets mentioned will do the trick.I know LMC has them,since I know a guy bought them.
What was the problem with the brackets?
Old 04-06-2008, 10:32 AM   #4
Bob B.
I ran into this on my truck. Had a hard time finding rear spring bushings, as '67 and '68 rear leafs were narrower than '69-'72 (Mike C is right, '67 and '68 4X2's are 2.25"). I was told that many Ford pickups had 2.25" wide rear springs. If that is true, you probably could make the Ford hangers work. I would think you probably could find someone around here with the right ones though.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is online now   Reply With Quote
Old 04-06-2008, 02:49 PM   #5
If you find 2.50" bracket you can always use spacers.I guess I had it backward on the width.I knew they weren`t the same as`69-up.
