Old 04-06-2008, 01:44 AM   #1
renagadebee34
taking my 305 out of my truck!!
im taking out my 305 and puting in a 350, how hard is it to do, i tryed cranking on the bolts that hook to the transmission buti couldnt get them to turn, is there anything i really should know before doing this?
girls love guys like me!!!!!!
renagadebee34 is offline   Reply With Quote
Old 04-06-2008, 03:30 AM   #2
RWJJR
RWJJR's Avatar
Re: taking my 305 out of my truck!!
Wel if your having trouble with the bell housing bolts..............you might want to get a buddy to help you with it.Not trying to be a smart A$$,but..
1980 Silverado short bed
1993 GMC 1500 LS swap
2006 Lifted Z71 Crew Cab
RWJJR is offline   Reply With Quote
Old 04-06-2008, 03:36 AM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
What experience do you have in this area? That will tell us where to lead you on this project.
Old 04-06-2008, 04:17 AM   #4
andresco50
andresco50's Avatar
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 04-06-2008, 04:49 AM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
its not that hard the trick of it is to try and do things systematically so you do things in order
first drain the coolant
disconnect the battery
remove the radiator and hoses
remove air conditioning hoses
remove power steering pump and lay to side
disconnect smog stuff if any
remove alternator and belts lay wiring to side
remove bolts that old exhaust manifolds to heads
disconnect plug wires and remove distributor
disconnect fuel line
drop inspection pan and starter
remove the motor mount bolts
loosen / remove the six motor to trans bolts
remove the torque converter to flywheel bolts
yank motor out using a pry bar and hoist
install is reverse of removal
someone reasonably mechanically inclined could do this over a weekend
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-06-2008, 05:13 AM   #6
1966gmc
Why does it taste purple?
1966gmc's Avatar
Easy as pie.Im goin to be re-installing the engine in my truck this coming week.It took me less than 2 hours to yank it out,lets see how long it takes to put back in lol.I have done a complete swap in a 85 Caballero in less than 8 hours.That was including the 2 hours spent trying to get the "Direct fit" headers to fit right
1966gmc is offline   Reply With Quote
Old 04-06-2008, 05:49 AM   #7
renagadebee34
i have mostly everything you said disconnected, i am pretty good mechanically and my buddy did it with his 74 nova, i was mainly worried about how i get to all the bolts that hook from the transmission to the block and how to disconnect the flywheel from the clutch, i couldnt really get a picture that looked good
Old 04-06-2008, 06:41 AM   #8
old Rusty C10
ive never done a standard trans without removing the trans first and removing the motor with the bell housing then once out of the car doing the clutch and all
Bob
I hate cancer!!
Old 04-06-2008, 08:09 AM   #9
lurch115
lurch115's Avatar
i agree...it is genrally easier to separate the bellhousing after you pull the motor....with automatic trannys it is easier to separate the tranny and motor after its out also....dunno if you can pull motor and tranny out with a manual tranny though.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
