04-06-2008, 05:48 AM | #1 |
Track results....
I'll post some videos as soon as I can work with the files.. But here is a picture from today..
These were all still motor passes today with no bottle. Best 3 passes of the day: 1.678- 4.856- 7.580- 89.735- 9.949- 11.968- 113.219 1.735- 4.952- 7.688- 89.650- 10.046- 12.056- 113.235 1.693- x.xxx- 7.691- 87.851- 10.094- 12.146- 109.703 I think I will try taking my 100lb tailgate off tomorrow, make another motor pass, then spray on it. |
04-06-2008, 09:15 AM | #2 | |
Re: Track results....
Very nice. Can you list the specs of the truck?
Anthony |
04-06-2008, 11:17 AM | #3 |
Daily Driver
nice. i see you ditched the mickey et's and went big.right on man.wish i coulda made it up to sac.what tire is that? looks good
nitrous...the equal opportunity destroyer. |
04-06-2008, 06:28 PM | #4 |
Tires are 30x13.50 ET streets..
347ci LS1 / 4L80E 4,400 verter (flashes to 4,800 though) Motor makes 430 to the wheels 3.73's weighs 3800 full tank of gas 55% front / 45% rear (added about 100lbs to the tailgate after the weigh in) Launch videos http://73-ls1.com/63truck/track4-4/Launches.wmv Last edited by Super73; 04-06-2008 at 06:28 PM. |
04-06-2008, 10:19 PM | #5 |
whats done to the motor?
Anthony |
04-07-2008, 01:21 AM | #6 |
Registered.........
Hey Super 73,
Nice Truck! Man, that thing launches great and sounds just plain evil! I was wondering, are you going to be at Sac on the 26th of this month, some friends and I are going to be bringing our junk to the track for a day of racing. Here's the the info: Sat...26 Test and Tune Drag Racing All vehicles must pass a regular tech inspection. Vehicles quicker than 10 seconds will run single passes. Times: Pit Gates Open: 10:00am. Testing 12:00pm-4:00pm Admission: General Admission: $10 Racers: $50 (car and driver) Sat...26 Grudge Fest Drag Racing Race your friends or just the clocks Times: Pit Gates Open: 4:00pm, Racing 6:00pm-10:00pm Admission: General Admission: $5 Racers: $35 (car and driver) One friend will be trailering his 1954 GMC 3/4 ton (formerly a long bed), Hillborn injected Caddy 500 powered backed by a tremec 5 speed drag truck, I'll be bringing my 1966 C10 panel to race ( It's nowhere as fast as yours! ) and have some fun, as well as a few other trucks/cars. We will probably be there all day from noon to ten, if you can make it I'd love to see your truck in person/make a pass or two. Pete
1966 C10 panel-400 small block/TH 350 combo Nothing is fool proof to a talented fool! Popcorn: Pops at exactly 444 degreese Expands to 44 times it's original size Has a 4 year shelf life Last edited by wild one; 04-07-2008 at 01:22 AM. |
04-07-2008, 02:34 AM | #7 |
Motor has forged rods/pistons, stock crank, ported stock heads 243/250 @ .050 .610/.612 108/110 cam, underdrive crank pulley, stock LS6 intake with ported filled throttle body and F-body long tubes.
I'm not sure when I'll get to Sacto again.. I promised my wife I would put the truck away for a little while and get some crap done around the house since it is staying lighter longer now. |
04-07-2008, 04:07 AM | #8 | |
Thanks for the info. I always liked the LS1 power. Where are you located? Never heard of your town.
Anthony |
04-07-2008, 08:07 AM | #9 |
It's near Montery...
04-07-2008, 09:39 AM | #10 |
BAD BOW-Silverado XST
Nice runs!! Love the video of launches!
04-08-2008, 02:21 AM | #11 |
Best pass http://73-ls1.com/63truck/track4-4/100shot.wmv
I lost a fuse on the second stage so that pass was only the 100 shot at the 60' mark. The second stage is a 200. I was going to use them both same time. I think it would have gone at least 10.999999. |
04-08-2008, 06:00 AM | #12 |
link won`t work for me.
Anthony |
04-08-2008, 08:53 AM | #13 |
Here are all the passes we got on video..
Best pass on motor was 11.9x @ 113 Best (only decent N20 pass, lots of issues) was 11.28 @ 115mph spraying a 100 shot from the 60' mark. Tried grabing all 300 after the 1-2 shift but the fused poped in the direct port. http://73-ls1.com/63truck/track4-4/s...08_low_res.wmv Last edited by Super73; 04-08-2008 at 09:18 AM. |
04-08-2008, 09:05 AM | #14 | |
Anthony |
04-08-2008, 09:19 AM | #15 |
04-08-2008, 09:28 AM | #16 | |
Anthony |
04-08-2008, 09:33 AM | #17 |
Hay Team!!
Super...are you running a front sway bar on yours?
Truck is looking good!
1972 Chevrolet Cheyenne LWB "Orange and White" 8) Last edited by Outlaw72; 04-08-2008 at 09:33 AM. |
04-08-2008, 09:39 AM | #18 |
No sway bar.. Why you ask?
04-08-2008, 09:42 AM | #19 |
Hay Team!!
Because mine is still on and I was thinking of taking it off....just to see how much it helps to transfer some of the weight...
1972 Chevrolet Cheyenne LWB "Orange and White" 8) |
04-08-2008, 09:41 AM | #20 |
It's still injected using a F-body PCM and harness. I'm runiing a 4L80E trans (Heavy beast). Stock 12bolt rear with 3.73's. 4,400 converter with 30" tire.
04-08-2008, 05:43 PM | #21 |
Thanks. your getting awsome power from that motor. Really doesn`t matter but i`m curious, whats your fuel mileage like?
Anthony |
04-08-2008, 05:31 PM | #22 |
Mine never had on and there are no holes for the mounts either. I'm wondering if this is a later addition. I do have a front sway bar at the shop though off a 8luch dually that I was thinking about putting on. Just to see if it did any good/bad.
04-08-2008, 06:33 PM | #23 |
Here is a detailed spread sheet showing all the times from this weekend. N20 passes are in Blue, only one was at full pressure. Red backrounded items are things that I feel were out of the norm and could be improved. IE the 11.2x N20 pass, I shortshifted 2-3 and only gained 19.x mph where even on the motor I'm gaining an average of 21.x on the back half.
http://73-ls1.com/63truck/track4-4/ET_Sheet_4_2008.xls Fuel Milage?? Now that's funny.. When this heads cam package was in my buddy's 2000 Camaro, he would knock down 20-22mpg on the way to the track. I get 10mpg.. I think I have some more tuning to do at cruise and can get more out of it, but I am going through wideband very quickly. It's rather sad. |
04-08-2008, 10:04 PM | #24 |
I`ll bet the camaros aerodynamics is quite a bit better than the truck so that will play a part too. On something like you have mileage doesn`t really matter, at least to me, I was just curious what you got.
Anthony |
