I am thinking about putting 3.08 gears in my 72. Does anyone else run these. I currently have 3.73 and I get about 10 mpg @ 65mph@ 3200 rpm. Just wondering if it will be completely gutless with that high of a gear? I still have the TH350 tranny. If anyone could give me their opinion it would be great. Thanks.
'72 Chevy C10 383, 700r4, 3.73's A little rust never hurt anyone. I consider it weight reduction. |
Re: Gears?
I have 3.08s in mine, I like em. I also have a Oldsmobile big block so low rpm torque isnt a issue. I wouldnt recommend them for a drag car but for a daily driver they work great and are alot cheaper than a overdrive transmission.
#3 | |
Gettin By on Gettin By
Re: Gears?
What Olds BB and trany are you running ?? I've got a Buick BB and love it. Thing gets about 18mpg. Gotta love that torque. |
#4 | |
Still Just Havin Some Fun!
![]() Join Date: Jun 2007
Re: Gears?
a green one with some stuff done to it.... |
![]() Join Date: Jul 2005
Re: Gears?
I do have 3:08 in one of my ole heaps, with 27 tall tires. I like them just fine. Steady speed 55-60 was around 15 mpg mabe a bit more. Also There was some turbo blue mixed with this pump gasoline
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
Re: Gears?
I am wondering the same thing. Ive got a small block and turbo 350 with a 4:11 posi and have a complete 3:08 setup to put in so i can hopefully boost my mpg's. I do not have a tach so am unsure of where i am even running at right now.
The Older Generation
Re: Gears?
I have a 454/TH400 combo in the white truck and it had a 3.73 open rear in it. It seemed to work the motor a little hard so I changed it to a 3.07 open and it made the truck a lot more drivable and it still has plenty of low end torque. You don't say what engine you have so I am going to presume 350. I think you would be in good shape with the 3.07. Just my 2¢ worth. LockDoc
![]() Join Date: Mar 2005
Re: Gears?
i changed my rear end from 3.73's to 3.08's and i like it. 350/sm465 w/31" tires. not as responsive as i would like at 55mph in high gear. but running 65mph or in 3rd gear it will pull pretty hard. no tack and haven't checked the milage, but it is not screaming going down the highway!!!
Re: Gears?
My 72 K5 came with the 3.07. It will generally get 13.5 mpg on the highway doing 65 to 70. The truck presently has a low hp goodwrench crate engine in it with the factory 4 speed. When towing with this combo there is no low end power. Once you get the truck up to speed its no problem but you better not be in a hurry to get there. When the truck was new and had a higher compression 350 it wasn't actually that bad for power. The dish piston 76 cc head crate motor is just a dog. If you have a true 9 to 1 motor and aren't in a rush the 3.08 will be fine and get you a little better gas milage.
Re: Gears?
I have the 350/350 combo in mine w/3:08's & 275/60/15's.
At 65mph it twists 2500rpm. My motor is nearly stock, with a mild cam, Headers, Performer intake, and Street Avenger 670 carb. I avg around 12-14mpg. But I've never gotten thru a tank w/o having my foot in it quite a few times. So it's hard to tell what mileage it really gets. Mine is not completely gutless with the 3:08's. And runs well once the rpm's get above 1500. For a driver, I think it's a good combo. I do ave a set of 3:73's just waiting for me to get a locker/posi unit of some kind. Shortly after those go in, I'll be getting a GV overdrive, or 700r upgrade to get my mileage back (and hopefully then some). Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() Last edited by Psycho71; 04-10-2008 at 07:38 PM. |
Re: Gears?
I had 2 2nd gen Trans Ams, one with 3.08 and the other 3.23 both basically the same 400 Pont. eng. and the one with 3.23's was alot quicker. Gas mileage was the same about 12mpg. and both ran 2500RPM at 65 mph.
Re: Gears?
Were there any other gear sets available? I have heard of a 3:42 gear ratio. Can anybody verify if trucks were available from the factory with this ratio?
Re: Gears?
I did not mention it but I have the 350sb motor. intake manifold, headers, mild cam, decent carb. I don't know if anything came with 3.42's. I know that you can get them though. Anyone have any experience with these?
Son of a gun
Re: Gears?
FYI guys, the truck ratio is 3.07, not 3.08. 3.08 is a car ratio. I'm anal like that
Bill BEATERS ARE NEATER |
#15 |
Re: Gears?
Sorry man, just going by what they have in Jegs. I will definitely tell you that this is not my field of expertise.
#16 | |
Re: Gears?
#17 |
#18 | |
Re: Gears?
Rottenwood Garage 1970...71...72 C1500 aka Orange aka Sideshow Bob 540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600 2 Tons of Fun |
#19 | |
Re: Gears?
But like you said, the torque is great. Stock specs are 205 hp and 345 torque for this year. 71 or 72 had more like 360hp and 480 torque. i like it. |
