10-31-2002, 08:58 PM | #1 |
Battery cables
From the battery, where does the positive go to and where the negative?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
10-31-2002, 09:05 PM | #2 |
72, the pos cable runs form battery down to starter larger hot post and neg cabe runs form battery to engine block with a bolt and bolt hole, i like to run another cable from engine block to frame rail in engine compartment and sometimes from there to fender or firewall. 3/8" bolts are great for this and 3/8" drill bit, you can get the copper crimp on 3/8" loop end connectors from auto parts stores cheap, i always use cables laying around and cut off the batt terminal end and connect copper ring end on when using them as grounding straps/paths for body to ground to engine, too much ground is impossible to have.
good luck |
10-31-2002, 09:05 PM | #3 |
Location: Bondurant, IA but in Worcester, MA for school
Positive goes to the positive on the starter solinoid.
Negative on my truck bolts right to the head on the pass. side of truck HotRod
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
10-31-2002, 09:07 PM | #4 |
Battery positive to large post on starter
Battery negative to ground on motor . ( be sure and ground motor to frame and motor to body.)
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
11-01-2002, 01:24 AM | #5 |
My other Love
I agree one can never have too many grounds. Even on my ford there is a ground strap on the hood. I dont know why maybe because fords are stupid
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
