04-12-2008, 08:44 AM | #1 |
Addicted to Chevy
What rear end gear do i have?
WHile cruising down the road at 2700 rpm, going 65mph with 32" tires behind an SM465 tranny?
i know there is a formula for all this, so even a link to the correct site would help. My rear end has no markings on it, I have looked. Thanks in advance |
04-12-2008, 04:16 PM | #2 |
Re: What rear end gear do i have?
It is probably 3.73 but could also be 4.10...it depends upon the accuracy of your speedometer and the actual (measured) diameter of the tire, not just the size marked on them.
04-12-2008, 04:22 PM | #3 |
[QUOTE=chev74;2673254]WHile cruising down the road at 2700 rpm, going 65mph with 32" tires behind an SM465 tranny?
i know there is a formula for all this, so even a link to the correct site would help. My rear end has no markings on it, I have looked. Thanks in advance[/QUOTE http://www.csgnetwork.com/multirpmcalc.html Could be this may help
The biggest problem people have, is other people Thou shalt be cool and not hassle Be a site supporter. The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
04-12-2008, 04:23 PM | #4 |
I just figured this out yesterday. I thought I had a 4.11 but NOPE! It's a 3.07. Im turning 3k rpm at 65 mph.
check out this post and scroll down to #6 http://67-72chevytrucks.com/vboard/s...d.php?t=286975 Post #6 Find the ID stamp and then go to americanclassic.com and use their VIN decoder to find your stamp ID. That fail safe way though is to pop your rear cover off and look at the stamp on your ring.
Rottenwood Garage 1970...71...72 C1500 aka Orange aka Sideshow Bob 540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600 2 Tons of Fun Last edited by OrangeCrush1970; 04-12-2008 at 04:26 PM. |
04-12-2008, 04:25 PM | #5 |
The Older Generation
04-12-2008, 04:30 PM | #6 | |
That stamp was right where you showed me Leon!
Rottenwood Garage 1970...71...72 C1500 aka Orange aka Sideshow Bob 540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600 2 Tons of Fun |
04-12-2008, 04:45 PM | #7 |
Sounds good. They can be hard to see if you not sure where it's located. Glad you found it.
LockDoc
04-12-2008, 04:53 PM | #8 |
Looked mine up a couple years ago too, that's how I found out for sure it was a 3.73.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-12-2008, 05:02 PM | #9 | |
Formerly yellow72custom
Best way to know what gears you have for sure is to pop the cover and have a look. The number of teeth on the ring and pinion will be stamped on the outer edge of the ring gear. For example, if it has 41 10 stamped, 41/10 = 4.10 gears. The fluid probably needs to be changed anyway.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg Last edited by lukecp; 04-12-2008 at 05:03 PM. |
04-12-2008, 08:34 PM | #10 | |
04-12-2008, 08:00 PM | #11 |
Addicted to Chevy
thanks fellas! ill see what i can do...
